Configuration/Options question... Premium Plus vs. Prestige
So I'm having a hell of a hard time figuring this out.
From what I can work out, optioning a Premium Plus with Technology Package vs. a Prestige without Driver Assist basically gets you:
- Adaptive headlights
- Audi Advanced Key
- The ability to opt for an even more expensive package in order to get dynamic steering and adaptive cruise
for basically $2,500 more.
Is that right? Are those the only features you're getting for the extra cash?
Lastly -- I'm sure adaptive dampers help the car, but do they help the car on the road or on the track? This won't be my DD so I don't care about making it softer for the road, but if the adaptive dampers help it handle better in the corners, it'll be worth $1k I think.
- Audi Advanced Key
Advanced Key is standard for both. Prestige as far as I understand is Premium Plus + Adaptive headlights + Tech pkg + B&O sound + the ability to add the driver assist pkg. The latter IMHO is worth having for the dynamic steering alone and if you do any kind of road trips or drive in traffic, the adaptive cruise control is a gem.
The adaptive suspension is solely for a more comfortable ride when daily driving it. Based on what I read, the adaptive suspension actually gives the car more understeer, because of smaller sway bars. Personally, I'm not a big fan of adaptive damping suspension as the spring rate and sway bars have to be compromised to work equally well with all three modes vs. a single setting suspension that has springs, dampers and sway bars optimized to each other. The only adaptive suspension worth having from a handling perspective is the DRC (Dynamic Ride Control), which in effect is an active sway bar, but unfortunately, we can't get it in the USA, not even on the RS5.
Great info, thanks a lot.
Your details reinforced my opinion on my loadout, which is as follows:
S5 Premium Plus
Daytona Gray Pearl
Manual Transmission
Sports Differential
B&O
Fine Nappa Leather
Technology Package
Black Optics (High Gloss)
@$60,950
S5 Premium Plus
Daytona Gray Pearl
Manual Transmission
Sports Differential
B&O
Fine Nappa Leather
Technology Package
@$60,950
My 2015 RS5 has all the goodies including adaptive steering. No understeer. Cannot get adaptive suspension.
2014 S4 Prestige has adaptive suspension but no adaptive steering option. No understeer.
Adaptive steering is most noticeable at speed. Stiffer. But the S4 is fine as well.
Both cars have adaptive differential which is a must IMVHO.
The RS5 is better in the twisties but the S4 is no slouch in Dynamic mode.
So if you are going to spend a lot of time in the twisties (I do) then you may prefer the dynamic steering but I believe you will be happy either way. Adaptive steering is quicker...less turn of the wheel. More sports car like.
Best
Best
I get the feeling (at least on the S5s) Audi is slowly eliminating the Prestige package. I had two S5 Cabs with Prestige and my '15 S5 Coupe is Premium Plus, but because it has the Technology Package, B&O and Adaptive Suspension it actually has more equipment that my previous Prestige models. The Drive Select can be set to Individual. I never had that ability with my '10 or '11 S5 Prestige Cabs. Yes, it's confusing.
You can't compare prestige and premium plus from different years...
For 2014, if you were ordering most of the options, then the Prestige was the way to go. When you eventually sell the car, you are selling a Prestige has better value than than premium plus + options.
For 2015, everything kind of changed. Prestige would be the way to go only if you really want the drive assist pack. Also for 2015, I donīt think you can get the rear sunshade.
It includes adaptive cruise control, the one that uses radar to maintain a set distance to the car ahead and dynamic steering, which is a variable ratio steering rack, that provides a sportier more responsive and direct steering with better feedback. It adjusts not only the steering boost, but also the steering ratio, but if you put it in dynamic mode it locks the steering ratio for a consistent response on the track or twisty mountain road, but the ratio is still more direct than the standard steering, so it feels sportier and more dynamic in every mode. It also integrates tightly with the stability control and the sport diff to further minimize understeer by making minor steering corrections at the handling limit. It's technically really a performance option along the lines of the sport diff, but for some reason Audi packages it as a driving assist feature. It does make parallel parking a lot easier, so I guess that's why. But in the S6/7 it's now part of the sport package that also includes the sport differential and in the RS7 it's part of the dynamic package, so I guess AoA also realized that they put it in the wrong package for the B8/B8.5.
Here's a good write up that describes how the dynamic steering, sport differential and audi drive select work together for a more dynamic driving experience.
quattro with Sport Differential: Dynamism Redefined - AudiWorld
Am I correct in understanding that you must get Prestige in order to get the comfort seats on an S5? I drove a Premium car without them and the seats seemed OK, but I have seen a number of postings and the C&D review which suggest the standard seats can be uncomfortable on long drives. I can't wait for an ordered car and all I can find available locally are Premium cars, so am trying to decide whether to accept a Premium without the comfort seats. Any input would be most welcome. Thanks!
