Disable Parking/running lamp
Hey everyone!
I have recently traded in my A6 for a 2008 A5 3.2 love the car, have done most of the VAG com mods myself. Now my question is, I have already coded the side markers to be disable, but now I still have some orange left, with the low beams on.
Is there anyway to turn off the other parking lamp, which is actually the indicator(turn signal) lamp? In which i have circled in the picture below. The lamp in question seems to be always on when the parking lights, or low beams are on, and when you go to signal they flash.
Thank you!
Thank you!
*Update
In case anyone was considering doing the same, after playing around with vag com, adjusting the brightness of the DRL when headlamp is on from 9-23% I have found the fix to my issue. Under the long coding helper, and the lesser menu that has "parking lamp active US" as byte 3, above that is byte 0, which has no indication of what it is next to it, I have unchecked that box of bye 0 and success! I no longer have any orange lit up with the headlamps on.
brouigu1
02-13-2009 08:17 AM
AudiSportB5S4
10-04-2008 05:36 PM
polishadonis
03-10-2006 09:58 AM
