Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
Help with flickering lights and gearbox malfuction warning sign
Old 05-17-2018, 08:04 AM
Martinsoon's Avatar
Default Help with flickering lights and gearbox malfuction warning sign
Hi there, driving a 2009 B8 S5 with 104,000 km or 65,000 miles on it.
Stopped at a traffic light and noticed that lights on dashboard and mmi were flickering on and off with gearbox malfuction lights coming on and a beeping sound. Restarted the engine and pulled over. Gave it a 10 minutes break before attempting to switch it on again. Headlights were flickering and engine couldn start. Audio and aircon were working. Tried a few more times and only exception was that dashboard lights would sometimes be completely dead or came on for a second or so before dying off. The gearbox malfunction light only came on the first time round and even then, i could barely see it as the warning sign would completely die. Anybody else experienced problems similar to mine? Any input would be appreciated 😀
shamel cooper (03-05-2020)
Old 05-17-2018, 09:41 AM
txtony's Avatar
How old is your battery? Battery lead connections secure and firm without corrosion?
Old 05-17-2018, 10:42 PM
smurkenstein's Avatar
I would check your battery - other than that, you need to pull some codes. The other thing to check is that there is no water in any of the electrics - check the cubbies in the boot. I had something similar with the flickering and (different) fault messages and the codes described general communication errors. There was water in the roof motor. Cleaned the drains, dried the electrics, had a new motor fitted and the problem has not returned since.
Old 05-24-2018, 11:18 AM
Martinsoon's Avatar
Thanks for the advice. Had the car towed to a workshop but they couldn't find a problem with it. Car started well the following morning. The only thing pointed out was that the alternator overcharged. Car ran well for a week but same thing happened today while trying to start it up. Can anybody help please😓
mrbilbill
04-05-2017 10:46 AM
mrbilbill
Telematics Discussion
04-05-2017 10:06 AM
AK_92_V8
09-24-2007 06:30 PM
looey
01-17-2005 05:28 PM
netsatwork
Audi 100 / A6 (C4 Platform)
08-23-2003 07:05 PM
Quick Reply: Help with flickering lights and gearbox malfuction warning sign
