I finally got the APR stage one for my 2010 A5 2.0T
#81
Find a guy with an APR chipped 2.0T A4 or A5. Like I said, what Audi put out on the market, the low end pulled somewhat but I was uninpressed with the top end. When my friend got chipped, it feel night and day.....the car wants to keep on going and won't stop when you're on it. Whoever is thinking about getting chipped....do it! And all the doubters out there, just wait till the trend catches on....sooner or later you'll be walked or left behind.
Of course, there are FMIC, HFC, and testpipe offerings already out for the 2.0T that should address the top-end discrepancy while further improving upon the existing low-end advantage should anyone choose to mod beyond ECU-tuning.
#82
ROFL wow, ignorance is bliss. I agree that the 2.0T doesn't have a vastly significant advantage over the 3.2 in gas mileage, but given the same transmission, driving style, and conditions, there is never a case in which the 3.2 will get better gas mileage than a 2.0T.
#84
I was really disappointed by the S5's performance figures. I opted for the 2.0t intentionally over it because I knew that with not too much money, I could meet the s5's top end and blow it's torque figure out of the water.
My experience with Audi is limited but I know as most of you do, that factory FI engines are built like tanks...
Seeing the variations in available re-maps, you know this is a stout block.
Exhaust, test pipe, custom intake, intercooler, water/meth, and a good dynotune and you'll have the S5... And for what, $3-4k?...
I'd rather have a unique FI engine over an NA motor any day of the week. Once you get boost, you crave it in everything!
#85
You can't defeat physics for cheap, no matter how much like to believe that. With $3,$4K you'll approach the performance of the 3.2, although, many think a chip is all it takes, it's not truly case, you'll need an exhaust as well.
#86
I think modding the 2.0T to S5 numbers is unrealistic. At least not without a bigger turbo that costs a lot of money and requires that you also upgrade some internal parts to handle the extra power.
Most people will only invest around $1.5k for chip and catback exhaust, which will net a decent performance gain over the 3.2. There's some talk about the benefits of a bigger FMIC but the only dyno I've seen comes from AWE (+20/20), which also happens to be the only vendor selling a FMIC for the A5... so the jury is still out on that one.
#87
To Specialized5223 who mentioned meth and dyno tune...those aren't currently available for the A5, so while they would be great and you would see major gains, they just aren't available.
#88
HAHAHA I just saw it had 420hp. I thought it was 365 for some reason.
Regardless, useable torque over once a month 120mph on the thruway is what I prefer anyway.
#90
spaniardone was being facetious since his 3.2 A5 eats Veyrons alive while simultaneously getting 6,987,453 mpg.
While I agree that a tuned 2.0T can easily make more torque earlier than an S5, the only way I can see making similar HP is going w/ a big-turbo setup, which have historically been $4k+ AFAIK. This will at least allow you to compete in the top-end. Let's not forget that Audi tends to underrate its performance figures, so the S5 may be faster than it seems on paper.
You can run the APR 100 oct program 24/7 w/ a meth kit, which is claimed to get you around 260 HP. Exhaust probably won't get you much more HP (maybe 10?) but a testpipe may add another 20 HP. OEM Audi intakes are already very efficient so an upgrade there will probably only change the sound of the car and not give you any noticeable performance gains. As for an FMIC, I believe ppl run either a meth kit or an FMIC, but not both.
So that's why I don't know that a 2.0T can make north of 300 HP w/out going w/ a BT setup. It may not matter tho. The current S5 makes about 350 HP IIRC but also weighs about 200 lbs more, and a tuned 2.0T easily makes more low-end torque. The bigger concern is the supercharged V6 that's currently in the S4 and that is coming soon to the S5. Think stock power of the S5's V8 combined w/ the tunability of the 2.0T.
