Installing S5 Badge on RS style Grille
Hi Guys,
Today I attached my S5 badge from the original grille to my RS style grille. The entire process was very simple and took about 5-10 minutes. I figured I’d share the how to in case anyone is interested in trying this method.
1. Drill a hole large enough for a zip tie to fit through.
2. Slide a black zip tie through the hole.
3. Wrap the zip tie around the bar behind the grille and tighten the zip tie but keep it loose so you can slid the thick peice to the back
4. Slide the thick piece to the back and tighten it as hard as you can. This may take sometime and it is difficult to work with such small honey comb openings. Once done, slip a pair of slim clippers in and clip the slack from the zip tie off.
Done!
Done!
Eiso
TT (Mk2) Discussion
10-08-2009 12:31 PM
Kevin B
03-09-2007 04:15 PM
Str4nger
Audi Original "S" Cars
02-28-2006 07:12 PM
MuRaN0Daddy
11-20-2005 07:15 AM
KOpork
08-04-2001 07:37 PM
