Newbie FreedomPop Sim Help
I'm new to the forum and new to the Audi world. Before purchasing my car, I looked up and down for instructions to get the Freedompop sim up and running in my B8.5 S5, but unfortunately for me I'm still getting a Grayed out 2G icon and no signal. I've activated the Freedompop Sim, and it even assigned a Number (not sure if that matters). I believe my MMI unit is capable to handling the Freedompop sim here in the Mid and North NJ area, but for whatever reason I can't figure it out. Might be my APN setting, might be my Head unit has the modem that can't handle the Sim. I'm sure I need a update to my unit both system and maps.
I've tried various APN setting based on what has been listed online, yet I seem to not have any luck right now.
Any suggestions?
Any suggestions?
Subbed to see if you can get this to work...
Any suggestions?
Any suggestions?
Activate SIM (if purchased directly from FreedomPop, then it is already activated)
Take out the old SIM
Turn on the ignition
Wait for MMI to fully boot
Install new FreedomPop SIM
Go to Telephone - Settings
Click on Connections
Click on Data Connection
Click on Connection Settings
If APN is set to the factory settings, then change APN to "fp.com.attz" (no quotes)
Keep everything else blank
For me, the old SIM in step 1 was my Audi Connect SIM. I left the Username and Password fields blank without adding a space.
BTW, your software and NAV database versions are a bit out of date. I updated my maps in October of 2017, so there's probably a newer version out. The "P" in your P0566 indicates the original factory install; the "K" in mine is for a dealer-installed update.
I have a '15 S5 with MMI 3G+ and I've been using a FreedomPop SIM for about 2 years now. Did you follow these instructions for setting up the SIM?
When I bought my car a few weeks ago, it didn't have an Sim Card in it, don't know much about the previous owner. Before I put the new Sim in the Car I reset everything to the Factory default setting via the Settings menu. The Sim is active, and I put the APN settings as listed on the FreedomPop packaging, which is the same thing you just said.
I think my unit might have the older modem in it, I'm trying to go to a dealership to check sometime soon. Also I've tried calling FreedomPop to question if I purchased the wrong Sim via Amazon, but their customer service line is TERRIBLE.
I'll try exactly what you said again, see if it works, but if it doesn't I'll update the thread when I can confirm my MMI Modem and if it can handle the FreedomPop Sim.
Again Thanks for the response.
You didn't mention your model year, but the North American 2013 S5 came from the factory with the P0566 software. My 2014-built 2015MY came with P0733 software. Is your B8.5 S5 indeed a 2013?
I believe the "HN+_US", like mine, indicates that you have an MMI 3G+ system. Unfortunately, the 2013 3G+ is only compatible with T-Mobile and not AT&T. FreedomPop uses the AT&T network. The 2014MY was upgraded to work with AT&T 3G.
There's a lengthy thread on Audizine that you should read for confirmation about this info and for more details. https://www.audizine.com/forum/showt...-Connect-Yes-!
Jump ahead to the 02-12-2018 19:47 post by user DrGER.
idiotavant
26
01-06-2012 06:41 PM
D Spin
Canadian Discussion
03-17-2009 12:41 AM
2PUTT
NY / NJ / CT Discussion
10-02-2008 09:25 AM
