Thinking of 2011-2014 S5 manual
The S5 has been a dream car and am thinking of buying one. What are your thoughts on the V8 vs supercharged V6? What are common problems? I’ve heard nightmares about the V8’s timing chain and guides, but that may be the B7.
Now that these cars are getting older what should I look for? I don’t want to buy one and immediately dump 6k into an engine out repair.
Thanks!
joe from St Louis
Thanks!
joe from St Louis
I have a 2015 manual transmission V6. A good friend had a 2009 manual transmission V8. Have driven both of them. In my opinion the V-6 is superior in every way except sound. The V8 rumble of his car was awesome. Drivability and low rpm torque of mine is far better however. You do have to be a bit careful with clutch engagement on these cars. It feels like the clutch is barely strong enough to handle the torque. If you don’t slip it excessively it will last. Mine at 65,000 miles now feels just as good as when it was new.
Even some of the V-6s had issues with the upper timing chain tensioners. Mine were replaced under a service action at about 40,000 miles because there was noise on a cold start. That was not an engine out repair. The updated tensioners have been fine for 25,000 miles now. I expect no further problems. Otherwise the car has been totally perfect with no mechanical issues. Did have to have the SiriusXM satellite antenna replaced when it was new. My only complaint with the car is that the brakes, while perfectly adequate for a street driving or even a fun run through the mountains, are a bit inadequate for track day use. I learned that doing one 30 minute session at Atlanta Motorsports Park. Probably fine for someone just beginning in novice group but I overheated the pads and glazed them in just that one session. I’ve got a set of track pads for it now if I ever decide to track it again. About done with that though. 68th birthday in July :-)
Thanks for reply - Audi S5 vs TT?
either way will have to wait awhile. Prices are just insane. High mileage 10 year old cars selling for 60% of their original msrp. Crazy.
Moneypitlexus
Q7 MK 1 Discussion
10
11-07-2021 01:50 PM
KCcoupe
Pacific Northwest Discussion
12-11-2005 12:31 PM
CJKCyclone
02-03-2003 05:25 PM
