Audi A5 / S5 / RS5 Coupe & Cabrio (B9) Discussion forum for the B9 Audi A5, S5 and RS5 Coupe and Cabriolet 2018 model year and up
2018 S5 SB Brake Caliper Bolt
Old 01-04-2018, 02:47 AM
Southpaw80's Avatar
Default 2018 S5 SB Brake Caliper Bolt
Anyone know what type of socket I'll need to remove the caliper bolts? I wanted to change the front brake pads but discovered the mounting bolts are something I've never seen before.
Old 01-04-2018, 06:08 AM
N8!
N8!'s Avatar
Changing pads already? How many miles did you get out of the original set?
Old 01-04-2018, 06:19 AM
SCarGuy's Avatar
Received 1,091 Likes on 770 Posts
check places like ECS, they will have the correct socket set you need
Old 01-04-2018, 08:58 AM
machz's Avatar
Looks like you need a 7 point like this but I can;t say for sure. Most of the older ones were 10 point.
https://zhautotools.en.taiwantrade.c...i-1139525.html
Old 01-04-2018, 10:51 AM
Southpaw80's Avatar
I actually just picked up my car 2 days ago. Drove 5 miles from dealer to home. I had ordered ceramic pads to avoid the brake dust issue. Plan was to change the front pads while I swap out the summer tires for winter tires. That bolt head put a stop to my plans.
Now, I'm on a mission to find the proper socket for the job.
Old 01-04-2018, 11:18 AM
stan23's Avatar
I could be wrong, but I don't believe you need to remove the calipers to change the pads. I think the design Audi uses allow pad removal from just sliding them up from the top.
Old 01-04-2018, 03:47 PM
Southpaw80's Avatar
Unfortunately, this caliper doesn't have the open back where the pads are held in place with pins - where the pads can slide out after pulling the pins. This one is similar to what's on the Macan S. Except the bolt holding the calliper in the Macan is a Triple Square head. I thought the Audi would be also but it's not.
Old 01-04-2018, 04:03 PM
ArvX147's Avatar
You probably dont need to remove that bolt to replace the pads, on my golf R you dont remove the guide pins. They (likely) used that bolt to prevent accidental disassembly
Old 05-09-2019, 03:05 PM
Jay Velasco's Avatar
Default Lol
Only one person here know what this caliper is like the rest of you are acting like know it alls
Mister Bally (07-26-2020)
Old 06-24-2019, 09:23 AM
JasonBender's Avatar
Can anyone verify if the BRAKE CALIPER SOCKET(7-POINT,AS-22) that is mentioned in the link https://zhautotools.en.taiwantrade.c...i-1139525.html will work on a 2018 S5 Cabriolet?
Thanks.
Quick Reply: 2018 S5 SB Brake Caliper Bolt
