A5 launch control?
The A5's do have launch control because they have the s-tronic (dual clutch) gear box whilst the S5 has the trip-tronic (ZF) gear box with a "quasi" launch control.
The ZF transmission employs software to balance the brakes against the torque converter being stalled up with the engine held at a predetermined RPM to provide the "quasi" launch control but not as aggressive as a clutch-dump launch in a manual or dual clutch.
The s5 has launch control, not similar to the usual S-Tronic where it drops the clutch, its more of a brake torque and then adjusting the shift points etc to optimize 0-60 times.
Originally Posted by 3cat
How is it engaged/used? I have an S5 and haven't figured this out.
The manual implies that it can be hard on the components (not surprising), but it doesn't say any damage would occur. See page 100-101 of the manual, which says: "When accelerating using the launch control program, all vehicle parts are subject to heavy loads. This can lead to increased wear."
