Damaged brake caliper
#11
Club AutoUnion
#12
Early production 2018's had the S logo on the rears as well, but that changed sometime last year. Same on the S4's. Your pictures are normal for current production.
https://www.audiworld.com/forums/s4-...mbers-2946281/
#13
You are not going to have a car with the same calipers in the front and the rear.
The fronts are 6 piston fixed calipers, and the rear are single piston sliding calipers. Your car without the "S" cap over the rear caliper is correct.
#16
Club AutoUnion
#17
Fe stick on wheel weights 5+10g, S-FE-001A
Material Fe(iron)
Weight Size (5+10g)×4
Surface Treatment Dacromet coated
Tape available with blue,Norton and 3M sticker
Thickness 3.8mm
Type stick on
#18
I went out and popped the tires off to get a better look. (Just what I wanted to do on a sub-freezing Sunday morning!).
And, here's a little extra surprise I found on the garage floor after the wheels were back on! What does the "FE" stand for? "Freakin Extra" lol. So now I also have a wheel that's out of balance.
#19
Also, those aren’t Audi factory wheel weights that you found. So either a wheel was rebalanced at some point, or they are from a different car. See attached photo I just took of my RS 5 wheel for the zinc wheel weights used by the factory.
#20
I'll get the wheel rebalanced if I can feel a difference when driving.
