Drive System Malfunction
I have a 2018 A5 Sportback (B9). While passing a car (hard acceleration) the car started to vibrate significantly and simultaneously I received a "Drive System Malfunction" on the display. After passing the car the vibration continued. The best way I can describe it is a low frequency vibration that increases in frequency with the engine RPMs. The vibration is very noticeable and can be felt throughout the car - car shaking. It feels as though something in the drivetrain is out of balance. I drove it another 10 miles to get home with the car shaking all the way. The shaking/vibration was bad enough that I wasn't sure I would make it home.
Once I got home I shut to car off and on restart everything returned to normal. I haven't accelerated hard yet with it to see if I can recreate the problem but I did call the dealer. Audi service's answer was that this was caused by the weather we have been having (Humid and very rainy) and that if I had any more problems then I should bring it in. I found that answer completely unsatisfactory since nothing about my experience with the car was normal. This is my first Audi and I hope that I don't regret it.... Has anyone else experienced a similar problem?
Misfire detected, shut down the cylinder for safety but no damage or risk to the engine. The shut down cylinder causes an imbalance in the engine operation so it shakes.
In the future you need to pull over and restart the car to get the protection to disengage and the cylinder to try to fire again, which it will most of the time.
If the misfire persists (it probably wont) take it to the dealer and they will sort it out.
These cars are designed for weather so that a is BS answer. Do you have a scan tool to see if there are any errors codes? Either way, I would call the dealer back and demand they take a look at it or go to another dealer. Also, it all officially documented rather than just a phone call.
Also it's not a BS answer adverse weather can cause misfires.
You can restart the car without pulling over, just shove it in Neutral first. Of course pulling over is always the safest option but it's not the only option.
That is what I was thinking... I am going to pull codes when I get a chance this weekend and see what it says. If there are codes or if it happens again I will take it in to the dealer.
Really, please describe what you consider "adverse weather" because I've been driving various vehicles for 57 years in blizzards to hurricane-like rains and below freezing to above 100 degree temps, and NEVER had this problem with any vehicle. And, this is "normal" for an Audi A5?
