Driver side window does not roll all the way down
I have no issue with the windows rolling up or down. The auto-down/up functionality worked and the windows make a good seal when the door closes. But I do have an issue with the driver side window. It will roll down, but not all the way. It stops about 1/2 an inch from being completely open. The passenger window rolls all the way down.
I fee like I've seen this posted before, but I can't find any answers. Has anyone experienced this before?
Pjstack (01-26-2022)
Thanks. Just tried it. Driver side window is still about 1/2 inch away from being fully open.
Club AutoUnion
Not an expert but if I remember correctly after you do what Richr suggest, you close the window completely, hold the switch in that position for a second or two and that should calibrate both the up and Down travel.
Good Luck and I hope this helps.
So, for whatever reason, the window rolls all the way down now. But, now I have the issue where the distance for the ACC always resets to 3. That's never happened before. I've always had it set to 1 and it never changed. But for the past couple days, the distance will always revert to 3. Weird.
Page 117: Distance 3 is set automatically each time you switch the ignition on. If you would like to set another distance as the default setting, you can have the adaptive cruise control menu enabled by an authorized Audi dealer or authorized Audi Service Facility.
