Installed a new Subwoofer (NON B.O. Coupe)
#81
Unfortunately the pioneer, like most shallow subs, wont hit the deepest frequencies very well without an enclosure. The kicker can get down below 30 hz which is pretty impressive for free-air. It does hang down a little but it's not bad if you use a spacer like I did. Maybe I'm jaded since my last S4 had a Pioneer champion series subwoofer in that location and it's magnet was truly ridiculous and did actually create storage problems in the trunk.
#82
I was looking youe Pioneer TS-A2500LS4, but what i see there is diffrent sizes and power. Can you please shere the link orspecifications of your sub and amp also?
CompC10 from Bobby Kinstle also looks interesting, i think both options are great.
What do you think about welding a new brace bar under the rear deck, and/or cubby holes in the boot. (Bruce_miranda have sent the links) also looks very interesting.
What is generally best position for sub for sound and to avoid rattle and vibrations or it doesn't matter much?
#83
I downloaded the app. I will try to use it soon. 😜
https://jumpshare.com/s/m9gKoaSZwAK1WYWf9LIO
https://jumpshare.com/s/xeY4KHsZbepHj2qtFZjK
#84
Thanks to everyone who joined the conversation since the beginning of this thread. I have find few very interested options and now i will explore more and decide which one i willl try.
Pioneer TS-A2500LS4
CompC10.
Kicker Hideaway HS10
SUB SPEAKER ENCLOSURE BOX/BASSER enclosures
My sound sistem is B&0, and the thread is non B&0 so i hope this will works
Cheers 👍
Pioneer TS-A2500LS4
CompC10.
Cheers 👍
#85
You can just search the pioneer part number via Amazon it's 1200w. I'm using a small class D 250w RMS amplifier.
My application didn't require the metal brace under the rear deck, more powerful setups may require it.
Subwoofers will propagate vibrations no matter where they are placed it's kinda their job. Just mount and isolate rattles where needed.
Good luck with your installation!
Nikon1 (12-16-2023)
#86
Rcsac,
Can i apply your setup wirh B&O sound sistem, will RMS amll work with B&O amp? Or i need a KickerKey500 amp?
I m not able to do anything of any instalation by myself, probably i wlll find somebody for this job and just forward my wishes to expert.
I will probably start installation in February, but for beginning i will mount and isolate rattles where needed because its very annoying
#87
Hi Alpina540i. Thanks again for your reply.
Pleaae if you are available, how to remove subwoofer grill from a5 b9 coupe?
#88
Has anyone installed an amp in a B9.5 with the 12V mild Hybrid?
I know the first step for any electrical work is to disconnect the negative terminal... since my car has two batteries.. looks like I have to disconnect middle wire on the 2nd battery and then measure the jump start point in the engine compartment to make sure voltage is 0.
When i re-connect have to reset the windows and will get warning lights until I drive a few miles. Anything else I need to worry about?
I read somewhere that the TCM settings basic settings will need to be reestablished??
Hoping someone can share their experience with the 12V mild Hybrid.
#89
Well, my setup has served me well thanks to this thread, but my Audi goes away tonight on trade. I appreciate all the help from everyone on here. I doubt I will pull all the front speakers and mounting brackets, but I will pull the sub box, sub, and amp from the rear deck of my sportback and throw it on the sales page.
Again, thanks. You guys were invaluable.
Rcsac (05-15-2024)
#90
Coercion Shaman (05-15-2024)
