Kufatec dongle for traffic sign recognition
#102
Don't know if there are different versions of the dongle, but mine flashed red and green
https://youtu.be/3iK8zuGyGoE
(TSR is not working)
#104
My understanding is that it is impossible with VCDS or OBD11 since you must flash new firmware to the camera. Even if you find the files, VCDS does not have a flash option but VCP does. Free vs $$$$
#105
It is dead easy with VCP. You just need to load the parameter file for your camera hardware number that enables both Traffic Sign and PreSense. There is no upgrade of firmware or anything else involved. Once the parameter has been enabled in the camera, you can turn the Traffic functionality on using either VCDS or VCP.
#106
Predictive control
Have any of you guys that used the dongle found a new setting for the ACC called predictive control ? I have a 2023 S4 premium plus and I want predictive control: Adjusts ACC speed to curves, intersections, and road signs. My buddy has a prestige S5 of the same year and he has the option, the only difference between our vehicles is the traffic sign recognition. I hope if I get the TSR it’ll show that option as well.
#107
Permanent S Mode Member
#108
Good point, have you used the KUFATEC dongle? If so was it just as easy as plug and play ?
#110
I second this. I'd be going 85 on a highway and a slight bend would come up and it would slow me down 20mph
