Kufatec dongle for traffic sign recognition
#111
Vehicle has
-ACC w/ traffic jam assist
-Virtual Cockpit with Nav
-traffic sign recognition (just installed)
#112
I got the traffic sign recognition working on the vehicle which is great and I know there are mixed opinions for the predictive control, but I still want to activate it so I have the feature. If anyone can help or has information I would appreciate it, I'm not sure if it has to be changed under adaptations/coding or something else but that option still does not appear and I have all the requirements for the system to work now.
Vehicle has
Vehicle has
#113
#114
#115
@Stefan Zanev Can I use OBDeleven for now? Still has access to long coding and adaptations.
Adaptations:
Predictive speed limit regulation: not activated -> activated.
Traffic sign detection activation: not activated -> activated.
Long Coding:
Traffic_sign_detection: Byte 1 Bit 0 -> enable
Speed_limit_assistent: Bye 2 Bit 3 -> enable
Curve_assistent: Byte 2 Bit 4 -> enable
**Please record/screenshot your original values before making changes, so that you can revert in case of issue**
You should now have a new menu under ACC menu in the car section of the MMI. You will be able to setup traffic sign tolerance for ACC and also curve assistance.
These values were experimented on 22 S4 and 23 S5.
I have no issues or errors and features work. However i’m not sure if all my coding is complete. Only way we can confirm if we have everything enabled if someone provides a prestige trim dump of module 13(Coding and Adaptations) from either an A4, A5 or Q5.
Use coding at your own discretion.
#116
[QUOTE=Stefan Zanev;25818887]You need to make a few changes in module 13 - Auto Dist. Reg.
Adaptations:
Long Coding:
Use coding at your own discretion.[/
That’s amazing, thank you so much! I can get you a scan from a prestige S4, I probably should’ve mention this before but I work for an Audi dealer so I have access to cars and I can a scan long coding and adaptations for that car. Even though I work for Audi they won’t tell us how to activate these things.
Adaptations:
Long Coding:
#117
Adaptations:
Long Coding:
assistance.
Adaptations:
Long Coding:
assistance.
Premium Plus : B5 77 9F F2 58 FF EC 06 74 78 61 A1
Prestige : B5 77 9F F3 58 FF EC 06 75 7B 61 A1
Byte 3 Bit 0
Byte 8 Bit 0
Byte 9 Bit 0 & 1
kingfishgrapejam
European Discussion
12-27-2007 10:28 AM
d1rt [A4 Pröjekt]
10-31-2007 12:37 PM
