My first wheel clean with P&S Brake Buster
#21
I bought a gallon of this stuff about 8 weeks ago. I've been under-whelmed by what I've seen. I wrote to the company and asked them about dilution ratios as there is nothing on the label about diluting it. The company replied with "it can be diluted up to 1:15 based on specific needs." So, I started out at 1:4 and have moved all the way back to 100% strength to get a result I deem acceptable. When diluted, I found the cleaning power was weak and the product dried on the wheel way too fast and I ended up having to clean the wheel twice. The product works OK at full strength. I can't see diluting it. There are better products out there that can be diluted, if that's what you seek.
#22
Watched your video last week - thanks for posting! Are your wheels ceramic coated? Looked like a decent, quick, in-between, no-scrub option if you don’t want to go through the hassle of agitating but not as effective without the brushes.
have you been using the product since you filmed the video? Any additional thoughts?
#23
What other products have you used that you recommend? Always looking for ideas!
The only other product I was considering was the Auto-fanatics wheel cleaning foam but that didn’t look like it was for both wheels and tires and I’m lucky if I can find the time to do one let alone mixing, maintaining multiple products for just the wheels and tires.
I just ordered a gallon of the P&S BB so I’ll post back as I get more washes under my belt and see if I like this as much longer term.
#24
interesting. Everything I’ve seen suggests a 5:1 ratio but I used it straight out of the spray bottle for this first run.
P&S is known for their Bead Maker product...gets good reviews.
I've gone thru many wheel cleaners over the years, I'm only applying with a sprayer. No foaming. Somebody had recommended I try the NanoSkin non-acid wheel cleaner a couple of years ago and have been using that since. It is recommended to be diluted at 1:4 and it works well at 1:4. (The label shows this info.) It works great on rubber, does a good job of cleaning wheels. I bought a 5 gallon container on Amazon earlier this year for $67 - - that's a lot of wheel cleaner that should last a couple of years!
P21S is a very good wheel cleaner.
Autoglym's non-acid wheel cleaner is probably my all-time favorite, but it's $$$$ and very difficult to obtain in bulk in the USA.
A great bargain: Eagle One Black & Plasti-Coat wheel cleaner has the color changing chemical (reacts with irons) and I always like to have this on hand for difficult wheel cleaning. I bought a bunch at O'Reilly's when on sale, $6. W*mart shows it for $5.
#25
Club AutoUnion
I have used P21S on my Supra and was very impressed with the results. I had totally forgotten about that product until your post.
— John
— John
#26
Yeah, great product, John, but gets expensive when you use a lot.
reefer_bob
Auto Detailing Discussion
11-16-2007 09:42 AM
Sully
12
03-15-2004 06:38 PM
St3phen
12-05-2001 06:44 AM
DavidG
05-17-1999 02:46 PM
