Roof racks/load bars for 2018 on Sportback?
#11
Looks great. I had local detailing shop do the same on my A8L with the little squares of PPF to protect the car's paintwork from the rubber feet.
#12
Yes, There is an Audi specific part that Thule makes for our cars that attaches to the clamp. You can find it here. This is the one that I used for my 2018 A5 Sportback.
https://www.thule.com/en-us/roof-rac...45196-_-145196
So essentially, for a full rack system, you need to order three items:
Rack bars
Clamps
and the car specific kit
Rack bars
Clamps
That's perfect. Thanks again Tucker.
#13
Hi. A few questions for those who have done this.
First, a little background. I have a 2018 S5 SB and primarily want to be able to roof rack my kayak. I currently have SeaSucker roof rails, and while they work well for quick trips around town, I recently took a four-hour trip (each way) to/from the coast for some inshore fishing and was PARANOID the entire time that the suction cups would fail and my kayak would end up on the road behind me, potentially hitting whoever was tailing me. I'm planning to do such trips 2-3x/year and just want to be able to throw the kayak on top of my car, strap it down properly, and go without constantly worrying.
This looks like a great option, but I don't think I'd want to keep the rails on all the time. How easy are they to put on and take off, and how much time does it take to do so? One thing I do like about the SeaSuckers is that it takes about five minutes to put them on and about one minute to remove them. I don't mind if these rails take a bit longer than that, but if it's an hour install/uninstall each time, that would be good to know.
Also, what concerns are there about damage to the car's paint at the mount points? I see one comment about using PPF or similar to help with that. Any thoughts on how best to mount the rails to avoid paint damage, especially if I'm able to take them off when not in use?
Thanks much in advance for any info you're able to provide!
#14
#15
With sportback, the windows are frameless. The Thule bars have slim flat steel tabs that slip down between roof paint and top of rubber seal that is above the long aluminum trim piece that runs above all the windows. I see the act of slipping those flat steel tabs down between rubber and paint as a risk that pieces of PPF will help with. I plan on getting them added in a couple of weeks when my windows get tinted. Check pics of Tucker's red A5 early in this thread.Clearly shows where tabsslide under the rubber, and how his PPF pieces are fitted.
#16
Thanks for the info. I went ahead and ordered the Thule kit for my 2018 S5 SB and installed it yesterday. One issue I hit is that the vehicle-specific measurements it provides--42 in the front and 39.5 in the rear--didn't seem correct. Specifically they seemed too narrow. I assume that's because the kit is spec'ed for the A5 and perhaps the S5 is slightly wider? I reached out to Rack Warehouse about it, and they said that the kit is specifically for the A5 SB and that Thule doesn't have a kit that's designed for the S5 SB. They've offered to allow me to return it, and they've said that if I continue with it, it won't be supported. Obviously others have done this, and once I widened the horizontal gap slightly, it seems to fit well, but I wanted to see if others who installed the Thule bars on their S5s had noticed the same thing or not. And if not, did I perhaps do something wrong during measurement and/or installation?
Thanks much in advance (again!).
#17
I can't imagine there is any difference in the structural roof of the S vs A body. The S5 is essentially an upgraded A5 platform. In any case, the Thule foot pack fits perfectly, and the measurements are for where the pack sits on the cross bars, which is readily adjustable. Key is to get the foot pack tabs installed properly with the little positioning pins under the rubber trim engaged into the Thule tabs. That secures everything.
#18
Thanks for contacting Thule Customer Support.
The Thule fit option for the Audi A5 Sportback 5Dr is the same fitment for the Audi S5 Sportback 5Dr for models from 2018-2021.
Both use the 135cm / 53" Thule Wingbar Evo, the Thule Clamp Evo foot pack 71501 and the KIT 145196.
jchasse
A4 (B7 Platform) Discussion
08-05-2009 03:45 PM
jslerner
02-23-2001 11:11 AM
