RS5 Turbo Noise
RS5 Turbo Noise
Is there anything similar to an ECS Diverter Spacer on an RS5? I am looking to get more turbo noise out of my 21 RS5.
On my 18 S5 I installed https://www.ecstuning.com/b-ecs-part...028495ecs01~a/ to make the blow off noise a bit louder. Is there anything similar for an RS5?
NOTE: I installed an IE full intake and turbo inlet the same time I installed the Diverter Spacer so the noise I am missing could be a combo of all 3. It looks like intakes dont seem to do much for the RS5 other than looks so I was probably going to drop in a new filter unless I can get a could deal on a carbon fiber one.
Other than noise and looks, an intake won’t do much until you upgrade the turbo. The stock intake flows really well.
I don’t know about the S5, but for the RS5, 034 suggested against installing anything like that as it can cause issues since the ECU is expecting the “blow off” to be vented back into the intake.
When I upgraded from my S5 to my RS5, I brought over the CTS turbo intake I had. While its not as loud as it was on the S5 with a large single turbo, it definitely brought the turbos to life audibly, and I actually preferred it to the sound the S5 made. S5 sounded great but sounded like every single big turbo out there. The RS5 dual turbo sound when opened up sounds much more exotic, almost like a jet spooling up.
I took it off last month and put the stock one back on though because my IATs were crazy in this Miami heat, plus I have a track day coming up next week and need to prevent as much heat as I can.
FLOS5IN (04-14-2023)
How do you monitor your IATs? When you track it are you going to put the CTS intake back on or leave it stock?
You can see your IATs with an ODB11 or other data logger, but I use the JB4 interface on my phone. When you have it plugged in you can select several different digital gauges to view. I have IAT as one on mine. As for the intake at the track, I may put it back on. Mostly so I can hear more of the engine and look down at the RPMs less. I come from Mustangs where both the engine and exhaust are clearly audible inside the cabin with the windows up. Landing in the right RPMs on a downshift coming out of the second half of a turn is crucial and you don't want to be looking down at your Tach during that time to figure it out. I wish the HUD had a tach display in it, that would be perfect.
Had to postpone my track day so I registered for the one next weekend (April 22nd).
What do you think your quarter mile and 0-60 times will be?
Well I mean road course/raceway HPDE track day, not drag strip. However, stock on my dragy I've gotten 3.5s and consistent mid 3s 0-60 on a bumpy road. I haven't tested it with the JB4 yet.
https://www.audizine.com/forum/showt...1#post14902041
You might find the whole thread above to be useful as it provides a comparison of the stock and Wagner parts. Here is another similar thread, which shows installation pics and provides post installation IATs:
https://www.audizine.com/forum/showt...ghlight=wagner
The cooling effect of the Intercooler on IAT is shown in the first graph at the bottom of the following link. For example, look at column 16, which has the highest turbo outlet temperature (127C / 261F). The stock Intercooler reduces that to 41C / 105F and the Wagner reduces it to 16C / 61F when the ambient air temperature is 12.5C / 55F. The reduction in back pressure (31%) is shown in the second graph at the bottom of the page:
https://www.wagner-tuning.com/produc...200001162.html
Of course the numbers will change with the ambient temperature, but the Wagner until cools significantly better than the stock unit. In support of that, I just completed a track day last week in 80+ degrees with the Wagner Intercooler and Heat Exchanger. The real problem with high IAT is that heat soak sets in and power is reduced. I did not monitor the IAT, but I did not detect any drop off in power. The kit I installed is here:
https://www.wagner-tuning.com/produc...700001162.html
huwla
05-29-2003 09:18 AM
MyS4Fun
02-08-2002 06:32 PM
