What lives behind the drivers side front bumper vent?
Here?
Passengers side is closed off...
Oops, photos posted in wrong order.
Funny thing that radiators are essentially unchanged in design from 100 years ago. Still easily clogged with dust and debris. About time someone came up with a better alternative?
FWIW, those look like coolant hoses as opposed to oil or transmission fluid lines so I'm guessing it's just an auxiliary radiator. Happy to be corrected, though.
garberfc (03-16-2021)
Club AutoUnion
I am certainly NOT arguing but I'm amazed at the lines that attach to that radiator for Transmission Fluid - normally transmission fluid is circulated under high pressure, unless the Audi transmission has a low pressure cooling - heat exchanger system. Good to know!
I had to go back and find the coolant circuit diagram to double check this, but yes it has an ATF to coolant heat exchanger affixed to the transmission along with a thermostat.
Club AutoUnion
Thank You! Audi really is “tech smart”
