Audi A5 / S5 / RS5 Coupe & Cabrio (B9) Discussion forum for the B9 Audi A5, S5 and RS5 Coupe and Cabriolet 2018 model year and up
Wheel alignment specifications same for A5 and S5
Old 06-23-2022, 07:59 PM
Yoshimura's Avatar
Default Wheel alignment specifications same for A5 and S5
Are the wheel alignment specifications the same for the A5 and S5?
Old 06-23-2022, 11:54 PM
SMac770's Avatar
Received 1,931 Likes on 1,640 Posts
Yes. The front camber changes with ride height, but A5 1BA and 1BE and S5 1BD are all the same ride height and so the same front camber spec.
It's always easier to provide accurate answers to specific questions, ie, this suspension code vs that one, as opposed to generic models.
Yoshimura (06-24-2022)
Old 06-24-2022, 07:55 AM
18A5SB's Avatar
Not quite related ...but wheel alignment may throw off the camera for Lane Keep Assist. The two needs to be done together. Apparently only the dealers have the equipment and set up.
Old 06-24-2022, 09:18 AM
SMac770's Avatar
There's so much stuff that has to be "recalibrated" officially if you change front or rear toe, it's ridiculous now.
Old 06-24-2022, 01:36 PM
18A5SB's Avatar
Welcome to the world of safety improvements and drive towards (semi)autonomous driving. If the car does not have Lane Keep Assist or one does not care about using it then camera alignment would be immaterial.
Old 06-24-2022, 01:56 PM
SMac770's Avatar
Dynamic steering requires recalibration on either front or rear toe change.
Adaptive cruise control requires recalibration on rear toe change.
The driver assistance systems front camera requires recalibration on rear toe change.
But the dynamic steering update is just a rerun of the basic setting process, and doesn't seem to require the large external calibration aids of the "visual" systems.
Then there's the joy of things you have to recalibrate after removing the bumper cover.
Adaptive cruise control and the front camera (surround view camera, not the driver assist camera) if you remove the front bumper cover.
Side assist aka lane change assist if you remove the rear bumper cover (this is unchanged from B8).
caminos
Q5/SQ5 MKI (8R) Discussion
06-02-2010 02:55 AM
AlmosTT
07-23-2005 07:38 PM
XTHCX
05-17-2005 01:55 AM
Xel
10
03-12-2003 05:11 PM
jetboy737
10-11-2001 08:46 PM
Quick Reply: Wheel alignment specifications same for A5 and S5
