Winter Tires/Wheels for 2018 Audi S5 Coupe
Hi all, I just purchased Andros R9 18x8 wheels + Michelin X-Ice XI3 tires in 245/40R18 size for my new S5 coupe which has the SSport package and 19" Cavo design wheels in size 255/35R19. I am wondering if 1) the wheels I chose will interfere with the brake calipers and 2) is it true that the wheels do not have the tire pressure monitoring system but the ABS does? I don't want to buy a second set of sensors if not needed! Thanks in advance for your kind input! :-)
Whoever you bought the wheels from should have confirmed they would fit your S5. and, yes the ABS system does the tire pressure monitoring so no sensors needed in wheels.
TireRack's search wizard seems to indicate they will fit, but you're probably going to be the very first person to try so please let us know how it goes. Tirerack also says there are some 17" wheels out there that will fit and that has me very very skeptical that their wizard is 100% accurate after seeing how tight the brake clearance is on the S4 and S5's OEM 18" option.
The R9 is a very popular wheel choice on several diff Audis and I am eyeing a set for myself, although I have a 2018 S4.
Please post pics once you get them on...front wheels especially so we can see just how tight clearance is!
Thanks and I agree; however, this car is still considered new so much that my insurance certificate, DMV and most databases do not have this car loaded in their systems. I made the salesperson commit to letting me have them installed before I pay and haul them home just to find out in November that there's a fit issue. Yay for not needing a second set of TPMS sensors!
So according to the installer they fit. They just dry fit the wheel on without the tire because neither of us wanted to be on the hook to buy wheels that didn't work. I don't have pics of the wheels against the calipers for that reason. They look good. Fingers crossed.
I was also eyeing the R9's on TireRack.
BTW - you can get Audi center caps on EBay for around $15. I believe this wheel specifically uses 68mm caps.
That said... I am currently leaning towards (blasphemy) getting a set of nice Y-rated performance all-season tires mounted to my 19" Cavo's instead of getting a second set of wheel/tires. I just don't want to deal with swapping them out twice a year (and investing in the proper tools).
One of these days I'll quit waffling and make a decision.
