04 Allroad auto trans
Hello All,
I am new to this forum.
I have an 04 Allroad. I bought it for one of the kids. It seemed like a good deal, and it would have been, except the transmission went out within the first month. The thing only had 104k, and all the maintenance seemed to be in order.
Well come to find out, Audi says the trany fluid is "lifetime" which encourages people to ignore the trany service.
From what I have read, and seen (since I pulled the pan) is there is a clutch (the "DG" drum) which tends to come apart, when the valve body pressure regulator sticks and causes a pressure spike. That drum is designed a little weak, and the end blows out of it. I found the telltale shrapnel in the pan.
My question is, has any one here pulled and replaced a transmission in one of these cars? If so, what is the procedure they used? It looks to me like getting to all the bell housing to engine bolts is near impossible.
I may just end up selling the car for what I can get. It's a shame, since it is like new in every other respect.
Any input would be appreciated.
Thanks,
Carl
PS. i drive an 03 Allroad, with 75k and have replaced fluid and filter in the trany. I also replaced the pressure regulator in the valve body with the Transgo upgrade.
Thanks,
Carl
sorry to hear this ----I had a really small leak - where the drive shaft connects- I had a shop in the boston area do the repair......auto engineering.
I noticed that they had to cut a section of the exhaust system out and add a small section of exhaust pipe ( 3 inches) to replace the exhaust system.. so just a heads up on that.
BTW if you are in the greater boston area-----auto engineering does really good work - reasonable price
Hello All,
Thanks,
Carl
Thanks,
Carl
Rudy
S13driftnut
03-05-2018 05:48 PM
hillpc
03-19-2017 08:17 PM
Zaphod A8
17
04-11-2008 10:03 AM
tozoM8
02-06-2005 08:37 AM
