2005 audi allroad quattro 2.7t wont start after timing belt change
hi everyone I bought a 2005 audi allroad Quattro 2.7tt and I went t scanned for the engine light and after I was driving it about 2 hours after word and out of no were car turned off and found the tb snapped. so I replaced it and turn the engine by hand and didn't feel nothin weird. but now wont turn over
could it be cam timing?
if so ow to re time the cams?
I had an old Jetta Diesel engine that was damaged when the bolt that holds the crank shaft pulley suddenly broke due to metal fatigue. As a result the timing belt and pulley fell off the car at a high rate of speed resulting in catastrophic engine damage especially considering that the engine was spinning at around 2500-3000 rpm. I paid a mechanic around $150 to do the inspection which consisted of taking off the heads to discover whether there was any damage (there was). Good luck and keep your fingers crossed that no damage was done and the timing is off due to misalignment of the timing marks. The likely outcome is that the engine is probably damaged beyond repair due to cost. Sorry to be the bearer of bad news!
Eriks Dudarevs
01-22-2016 12:51 PM
