3rd rear brake light question ?
Not long ago purchased a 07 A6 allroad and after a very short time the 3rd brake light failed,someone I know mentioned they are a sealed unit and not repairable,I did however read on the net someone had opened one up and repaired it,is this possible or do I order a replacement ?.
Main reason for asking is I don't want to go to the trouble of removing it and find its not repairable,cheers.
Cool thanks,apparently you can get them apart....carefully.
I have some LED strip and did think of that,bit worried it will throw a code ? certainly will draw less current so think that may be an issue.
Comments thanks.
Comments thanks.
If you get a code or fault on the message center, add a load resistor 6 ohm / 50W
zviadi diakonidze
04-29-2019 03:55 AM
jaazmann
08-30-2012 08:38 AM
Ashleey
06-05-2008 08:37 AM
