Adaptive behavior
Old Jan 12, 2004 | 09:46 PM
allroad2point7t's Avatar
Default Adaptive behavior
Is it true that the Audi can learn one's driving behavior and adjust accordingly to promote that driving habit? Does the Audi perform better if I drive it aggressively?
Old Jan 13, 2004 | 03:17 AM
paulroad's Avatar
Tech Guru
Default Re: Adaptive behavior
THe tiptronic trans has internal settings.. sport, normal, etc. If you are driving hard, it will program to sport and stay there, quicker shifts...holding to a higher RPM, etc.
It won't learn the way home once get off the exit on the highway... too bad..
Old Jan 13, 2004 | 04:25 AM
CTallroad's Avatar
Mine took about a month of spirited driving to finally unlearn the previous owner and move to sport mode and thank God - it is so much better and appropriate for the way I drive. I wish I could tell you how to force it to select sport, but I can't. Anyone else?
Old Jan 13, 2004 | 05:33 AM
HPH's Avatar
HPH
Default Transmission reset...
...Although there's some disagreement about this, supposedly it's possible to reset the transmission to neutral (i.e., to unlearn its learned behavior) by: turn on key but not engine, hole accelerator pedal all the way down (you can feel the "kick-down" switch -- hold it past that) for > 5 seconds.
Also, for some model years (> 02, I think) you can use the VAG-Com tool to set the transmission to sport mode.
All this, and more, has been discussed extensively here and on the A6 board. HPH
Old Jan 13, 2004 | 06:00 AM
paulroad's Avatar
Tech Guru
I also believe excessive drugs will effect the brain....
Old Jan 13, 2004 | 06:47 AM
ShowMeData's Avatar
Default Sport mode via VAG-COM or dealer
My dealer kindly coded my TCM ('01) to permanent sport mode. I was never able to get the adaptive algorithms to make the switch, that I could notice.
Old Jan 13, 2004 | 07:11 AM
Paul3.2A4avant's Avatar
Yep, worked on my wife's old Passat and is well documented on VW forums.
Old Jan 13, 2004 | 06:57 PM
Ollie's Avatar
New Member
If it's a 2001, just put it to "4" instead of "D". Moves shift points to higher RPMs
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 13, 2004 | 07:07 PM
BG AR's Avatar
Default At the very least, it resets the onboard computer... had a check engine light on for
a couple of days, car was driving fine, so i did that procedure, and the light was gone...
Dave335i
S4 (B8 Platform) Discussion
29
May 11, 2022 06:01 PM
sirfrancis
A4 (B9 Platform) Discussion
55
Feb 22, 2018 03:33 PM
123Audi4me
Q5/SQ5 MKI (8R) Discussion
18
Feb 5, 2013 09:35 AM
Kugs11
Audi allroad
Sep 7, 2007 07:20 AM
nappin
Mar 7, 2004 10:40 PM
