Allroad ABS issues--ECBM or Controller?
Have talked to several Audi mechanics I know and they all say it's most likely the module, (normally is attached to side of pump and head and contains the electronics as well as the solonoids).
We ran VAGCOM scans and came up with several codes:
18034--Powertrain data bus missing--message from TCU
00302--ABS Solenoid Valve Relay, (J106)
01316--ABS Controller
01315--TCU no communication intermittent--this ties back to 18034 I think...
So...either the controller or the module is the culprit--but are they ONE unit or in two different places. Problem is for this year I have the Bosch 5.0 which has the ECBM allegedly in a different location than the pump/module location. Also found in the S-4, the 5.0 ECBM is located under rear seat. I looked in the Allroad and I don't see a computer...
At the head/pump, the black box attached to side has two wires coming from the bottom of the module and they go to the pump itself. The major connector lifts up and away laterally towards the fender but is vertical vs. horizontal in the other modules. 4 torx screws hold it to the side of the distribution head/pump assly.
Unlike the 5.3, the 5.0 isn't rebuildable per some of the sites I visited, because again, they say the module and controller are in two different places. My problem is I don't know where the ECBM is located. I've searched the net and nothing.
When I started to remove the module from the pump, I found the wires to be soldered and too short to snip and resolder without having to remove the head and pump. I had hoped I wouldn't have to crack the hydraulics on the car forcing a pressure bleeding.
Has anyone else been down this road and can you help? I only wish it was as reliable as my '95 S-6.
I've cleaned all connections, looked at TCU--it is dry and stable. Does anyone know if the 5.0 controller does in fact have the electronics in it, (vs. the S-4 which has it separate and under back seat?) Does anyone know what I should replace? A new unit, (again, I don't know if the ECBM would be considered part of this) is $992.00. I can probably scout up a used one for half that. I just dont want to replace the module when it could be the wrong piece.
I live in Chicago if anyone cars to weigh in. I really need help on this. Thanks.
Pat
