allroad Air Suspension Pump , Fuse or Relay or??
for me, time for a new car. no more allroads. Tired of the continual repairs.
S
Everything is working well now. Time for a new Audi. I think a 2007 A6 Avant with 3.2L and Premium package.
SST
40amp suspension fuse is blowing
yellow warning light on the dash blinks when I start it up, then ultimately goes solid, but the compressor is not turning on, and the car is sitting very low. FYI, both front airbags were replaced w/ Arnott Gen II bags about a year ago and the compressor portion was rebuilt 6 months ago using one of Andy's kits. all was working fine until the yellow light came on a few days ago.
should I try replacing the relay next or
should I either pull the compressor out or
try testing it while mounted by bringing 12 volt power directly to it?
if I try doing it while still mounted on the car, what will I need to make the connections? can it be done w/ jumper cables or will I need something smaller? please be detailed in your answer!
could the relay somehow be causing the fuse to blow???
is it a mistake to replace the relay 1st if I've yet to determine if the compressor will work when hooked up direct to 12volt? (I don't want to have to buy 2 relays and/or not know that the compressor motor might somehow damage the relay)
if it is the compressor motor, can just the motor part be replaced? if so, what's the part number and where best to order it from?
thanks for your help!
you cannot source the motor seperately new but a car breakers is the best option if you dont want to buy a new compressor, i have lots of spares parts but im in the UK shipping to the USA would be more costly than to buy in the USA
regards
Andy
regards
Andy
Miessler has 3 different model compressors for the Allroad
Compressor: Audi A6 C5 4B 1999-2006 Allroad, Quattro, Avant., AIR-SUS
Compressor: Audi A6 C5 4B 1999-2006 Allroad, Quattro, A...
View on www.air-suspension...
1) an OEM for $339 Euros
2) a new increased air model for $374 Euro (being released 2/15/2015)
4) and a long life straight piston model for 464 Euros
Jeremy
