anyone have the service CD. I need some help...
I need instructions on how to remove the headliner. I have to replace my antenna mount and I really don't want to ruin the headliner in the process. Any help would be geat!!!
Here are the steps for antenna R&R; headliner removal isn't needed.
TO REMOVE & REPLACE RADIO ANTENNA (AVANT)
Removing
- Carefully pry out rear interior light from roof liner using screwdriver.
- Unbolt antenna -1-.
- Unbolt hex nut M14 with serrated washer.
- Disconnect electrical harness connectors -4-, -5- and -6-.
- Remove antenna foot -2- upward.
Installing:
- Install in reverse order of removal.
HTH
Removing
Installing:
HTH
don't know if that is going to work, antenna connectors are cable tied to metal frame in rear
pulling the rear panel between tailgate and head liner would make it a lot easier. i am pretty **** and could not possible be happy knowing that antenna connectors were loose above head liner. : ) no way i could get my hand though hole where light is to reach back and undo ties. i don't have nav just cell and am/fm antenna.
yakev724
Q5/SQ5 MKI (8R) Discussion
10-26-2015 06:25 AM
PaulW
11-29-2003 10:03 AM
