Audi A6 Allroad 2003
Hi! I've got a problem with my Audi A6 Allroad 2003, 220k km. Neither I or dealerchip has found out what the problem is, so I'm now asking the big web!
So, when starting the car, usually everything is okay, and all the lights goes on and off as usually. Suddenly the car would gain rpm, from 8-900 to 12-1400. Together with this the ESP (cirkle-arrow with triangle and !), ABS and the suspension level light turns on. After a minute the car goes down to the regular rpm, and the ESP and ABS light turns off. The suspension level light is on until the car turns off. This happens mostly when the car is cold, but also sometimes when it's hot. Sometimes everything looks normal, and I start to drive, then suddenly it gains rpm, and the light comes on.
Today I tried to change the brake pedal switch, but no results (the lights could indicate that there's an error with it)
Please help, I'm desperate as it seems so wrong...
Thanks
Thanks
DoubleTrouble
New England Discussion
01-04-2008 03:37 PM
tags721
05-22-2006 03:51 PM
