Cold start problem
Old Jun 1, 2017 | 07:13 AM
dustboy's Avatar
Default Cold start problem
Hi folks, my allroad takes a couple tries to start in the morning, then when it does turn over it runs very rough for about 30 seconds. Then it runs fine for the rest of the day. No OBDII codes. I thought it was the fuel pump (voltage at the tank connector, didn't hear pump running) so I changed that out with no improvement.
Thanks for any help!
Old Jun 12, 2017 | 10:33 PM
leoparker990's Avatar
This was pretty normal to the Audi B8 OR B9. My friend has B9 and having same problem. I have Audi A4 and sometimes I also noticed the rough bounce right when I start my car. Have you check your car to dealer or ask about this?
Old Jun 13, 2017 | 07:13 AM
dustboy's Avatar
I brought it into my mechanic. He ran a fuel system cleaner thinking it might be a leaky injector, but now he suspects an issue with coolant temp sensor. He has replaced the sensor but the dash gauge is still reading inconsistently, so there might be an electrical issue elsewhere. Hoping to get it back today, he said if he can't figure it out, he won't charge me.
Old Jun 13, 2017 | 04:00 PM
PaperToast's Avatar
Banned
id start by doing a stage 0, changing spark plugs, coils, ect
Old Jun 13, 2017 | 08:32 PM
I think it might be electrical issue . I hope your car will be ok after checking by mechanic.
Old Jun 14, 2017 | 08:49 AM
dustboy's Avatar
Mechanic replaced the coolant temp sensor (that I had replaced with OE 3 years ago because the plastic clip broke and the sensor popped out like a champagne cork) and it solved the problem.
Old Jun 14, 2017 | 09:57 PM
Sounds good. congratulations....
Old Jul 24, 2017 | 10:55 AM
dustboy's Avatar
The saga continues...So the car died on a long uphill highway grade on a hot day. It would start, but stalled again after a hundred yards. This resulted in a $750 tow into town and driving my van 2 hours to rent a Uhaul trailer with a bad tire...another 3 hours on roadside. The next day it started and ran fine.
My mechanic and I blame the cheap fuel pump I put in...He replaced it with a VDO, lesson learned...assuming it solves the problem. I'm still dealing with the brake light problem, which may or may not be related (it certainly is oddly coincidental).
Old Jul 29, 2017 | 05:13 AM
hichamaziz's Avatar
thank you for thread
MiniSpdRcr
14
Jul 24, 2012 06:38 PM
SchwarzS6
Oct 12, 2008 09:11 PM
paulfern2000
10
Aug 7, 2006 05:42 PM
beyerdbx
Sep 29, 2005 07:47 PM
Quicksilver-A4
Jun 8, 2004 08:06 AM
