coolant leak, the puddle on the ground is midway (front/back) of the engine compartment on the
Old Mar 18, 2008 | 05:40 AM
kingfishgrapejam's Avatar
Default coolant leak, the puddle on the ground is midway (front/back) of the engine compartment on the
passenger side. I know it's vague but until I can get under it tomorrow night I figured I would fish for probable causes and pointers. Did a search found some links on the auxilary coolant pump but that didn't leave a puddle in the links I saw. Do the heater core fittings leak often on these?
Old Mar 18, 2008 | 06:42 AM
Rocky-in-Connecticut's Avatar
what engine?
Old Mar 18, 2008 | 07:02 AM
Screen Name:12345's Avatar
Default A minor coolant leak turned up to be a bad water pump...
on my 2001 passat. When the WP bearing suddelny seized, my wife pulled over and called me (she was in the middle of nowhere, in the night and it was snowing). We had the car towed to the dealer.
Old Mar 18, 2008 | 07:39 AM
audialex's Avatar
Junior Member
Default Re: coolant leak,
Mine did the same thing just a couple weeks ago. It only happened when the car sat for a long period (2 days), and gave teh plastic and metal bits time to contract enough to cause the leak. I then drove it for 2 more weeks with no re-occurance. Odd... I replaced my coolant tank several months ago, and maybe the new tank helped keep the pressure higher in the system, causing a leak somewhere else. Hope that helps a bit.
Old Mar 18, 2008 | 05:09 PM
ivonius4.2's Avatar
Default If it's a 4.2 it's a little plastic tube at the oil cooler...
...on the passenger side between the oil filter and the engine block. $5.00 part; 6 hour complex job to get to.
Old Mar 18, 2008 | 11:27 PM
yep this has been intermittent for a couple of months now but the puddle is much larger than before
Old Mar 18, 2008 | 11:28 PM
2.7t
Old Mar 19, 2008 | 07:44 PM
Default Well I put the car up on ramps and ran it for 10 minutes or so to get to operating temp with the
heat on high. Not on friggin drop has fallen. looks like I'll have to leave the belly pan off and play the hide and seek game.
Old Mar 27, 2008 | 11:38 PM
V E R D I C T : W A T E R P U M P
Drakken14
14
Jun 1, 2026 03:36 PM
jguthrie1
A6 (C7 Platform) Discussion
Feb 28, 2020 09:46 AM
beebe
Q7 MK 1 Discussion
May 21, 2019 06:04 AM
MBL2.7t
Aug 26, 2005 11:46 AM
KBob
Feb 10, 2003 12:25 PM
