Delivery Checklist & Break-in Period
My Highland Green 6-Speed (with Convenience, Premium, Wheels Upgrade, Bose Upgrade and Sunroof) is off the boat and on its way to the dealer for delivery in a couple of weeks or so. I know there have been some discussions about what to check for on delivery and break-in periods, but I'd like to get some current, quality input from fellow allroaders out there...
- What are the critical items to check for on delivery specific to the allroad? (I know windshield wipers have been a concern...anything else?)
- What is the true recommendation for breaking-in the allroad? I know there are general Audi guidelines but does anyone have more detailed insight on what is best to do in the break-in period and for how long, etc.? (I'm picking it up in Montana and will be driving it back to Seattle so I know I'll need to be running through the 6-Speed pretty consistently to vary RPMs and not go 100 MPH+ on I90...which will be difficult but I can hold back!)
Your insight is much appreciated!
Thanks.
~Tim (patience running thin)
Thanks.
Re: Delivery Checklist & Break-in Period
1. First 300 miles, Audi recommends you go easy on the brakes.
2. First 1000 miles, vary your speeds, don't drive on the highway at one speed for a long period of time, don't use cruise control.
I've always broken in cars the way I plan on driving them - but you still want to be a bit careful during the first 1000. Check you oil level as well during break in.
Other than that, you'll find that the first 1000 goes by pretty quick!
01/Silver/Tip/Loaded/Black Tint
Ok. Anyone have time for a formal checklist for this allroad forum?
Jordan
I found the delivery checklists that I used. There were two main ones I used
that are on the AudiWorld A6 forum site:
BAR 2.7T on 2001-02-28 10:45:05
SK on 1999-10-28 17:26:46
You should be able to do a search for those specific names on those dates to get
directly to them. A general search might lead to updates or newer lists as well.
I also got a good list from a BMW site at
http://e46fanatics.com/faq/checklist.html, it's for Bimmer's but I found it
enlightening.
The other non-Audi site I found helpful was called the Motley Fool. There is a
test drive check list and a delivery check list:
www.fool.com/Car/Worksheets/TestDriveChcklist.htm
www.fool.com/Car/Worksheets/DeliveryChecklist.htm
I would also suggest going back through the allroad forum to see what kind of
problems others have had. A few specifics that I remember for the allroad:
- run the wipers a couple times to be sure they aren't going to collide
- check the hose connection on to the radiator over flow tank
- have the tech's check the alignment (I discovered my rear was way off only
after the 5000 mile service noticed the pre-mature tire wear.)
- check to be sure all the accessories are there: cargo net, tool kit with tow
strap, spare tire, owners manual w/ Audi pen, floormats, first aid kit.
Finally, I would encourage you to pick up the car in the morning when you can
plan on spending as long as you need to do a complete check. And be sure not to
sign any papers or accept delivery until everything is to your satisfaction,
even if that means waiting a day or two until they have corrected any problems.
Good luck. Let me know how it goes.
Vince
enlightening.
Vince
gb4.2
22
09-28-2007 06:56 AM
Joe D.
05-05-2000 08:21 AM
