Help...about to pull the trigger on Stoptech 332 BBK from a B5 S4...
Please confirm this will bolt on w/o any modifications or if any, what is required. Part# 83.130.4600.51. Thanks.
That's exactly what I put on my allroad, except for the brake lines.....
Stoptech 332 setup that was taken off an 01 S4. Calipers, rotors and hats are a bolt on swap with no issues at all.
BUT- the S4 braided stainless brake lines are too short for the allroad. You will need to get a set from Stoptech. They're longer to allow for the height adjustability of the allroad suspension. #HYD85.130.4450 Sorry, don't remember what they cost.
<img src="http://pictureposter.audiworld.com/8639/st_on_car.jpg">
A friend of mine is selling them...
there used to be lots of Stoptech BBK's for sale. Strange how the market goes up and down on performance parts. Good luck.
Did you keep the splash shield or did you remove it?...
So, the caliper mounting hardware from the 01 S4 Stoptech BBK will directly bolt onto our allroad? I have an 04 with 2 pad calipers. I ordered the front lines, rear lines, fluid, front/rear pads, and Stoptech front pad wear sensors. Am I missing anything?
Yes I did, but just bent it back slightly...
Didn't take much to bend it to clear the rotor. Everything else bolts on. I only replaced the front brake lines, and left the rear ones stock.
My car is a very late 2002 so it had the 2 pad calipers originally too. Back in the spring I converted (backdated?) to the HP2 which was also a bolt on change in the hopes it would improve thr braking. It did especially in pedal feel, but not enough for the track. That's why I jumped on these Stoptechs. It's a really simple conversion.
98.5quattroA4
12-09-2009 05:54 PM
pac1085
12-15-2007 01:20 AM
Zach, USM
05-05-2005 08:28 AM
