help! aftermarket headlights causing multiple faults, Uwe very helpful, but...
Old Sep 29, 2009 | 08:19 AM
steinline's Avatar
Default help! aftermarket headlights causing multiple faults, Uwe very helpful, but...
Replaced my oem lights with the LLtek lights and they look and perform extremely well. Did throw the headlight range adjustment code immediately, since they are not autoleveling. I figured the car does that anyway, so no biggie. Uwe and Andy at Ross Tech advised to remove the headlight range control module, which did remove the headlight code, but then the suspension module threw codes:
00774 - Level Control System Sensor; Left Rear (G76)
57-00 - Electric Circuit Failure
00776 - Level Control System Sensor; Left Front (G78)
01771 - Control Module for Headlight Range (J431)
79-00 - Please Check Fault Codes
So, it appears these two modules talk to each other. Does anyone have any ideas, other than getting someone to ready the wiring diagram and explain to me how to close the open circuit that the xenon module "sees"?
help.
Old Sep 29, 2009 | 08:26 AM
steinline's Avatar
Default oh, and the coding for the initial control module fault...
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00030
Shop #: WSC 02334
3 Faults Found:
01539 - Headlights Not Adjusted
35-00 - -
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
30-00 - Open or Short to Plus
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
Old Sep 29, 2009 | 09:58 AM
allroaddave's Avatar
Unhook the suspension module too?
Seems like there ought to be a code in there somewhere that tells the computer to look for certainn things when the headlights are turned on, I have no experience with the VAG-Com, but if you have one, have you looked at all the possible modules that might effect this to try and turn that function off?
Seems they do NOT want you fiddling with their car, do they?
Old Sep 29, 2009 | 11:17 AM
DOALLAR's Avatar
It seems like your new HL's are not position correctly. Since you do have VagCom handy you can adjust them your self. If I remember correctly Ross-Tech does have procedures to properly aim new oem/aftermarket headlight's. You can start here: http://wiki.ross-tech.com/index.php/Main_Page
Old Feb 22, 2010 | 09:21 PM
Aqualove19's Avatar
Default Help me ,please?
Could anyone help me get rid of these codes, please?
Coding: 00030
Shop #: WSC 02334
3 Faults Found:
35-00 - -
vtraudt
Audi allroad
Mar 9, 2015 07:56 PM
CME's01S8
Sep 2, 2014 04:32 PM
Aqualove19
VAG-COM Discussion
Mar 20, 2010 08:31 PM
IanManchester
Oct 17, 2008 03:40 AM
DRAGON88
Jan 19, 2007 08:41 AM
