How to burp an allroad
This is what it's supposed to exhibit, right? Hot coolant goes in bottom, heat is extracted by blower, cooler coolant exits the top.
NOW what do I investigate?
Second, as long as the second pipe is not relatively cool, your heater core should be working correctly. The next step would be to check your heater doors on the interior. A real pain I'm sure. I have never done it and hope I never have to.
Good Luck!
If it doesn't, maybe the water pump is damaged somehow? I think some of the early pumps had plastic impellers that could lose effectiveness without catastrophic failure, but I could be thinking of a different motor.
I don't think the 2.7 has an electric coolant pump other than the after-run pump. ??
As for mystery water loss, if it's leaking around one of the coolant temp sensors on the cross-pipe at the back of the heads, the coolant will drip on the hot manifolds and evaporate, leaving no visible liquid, but a strong coolant smell.
Maybe take a look at the whole heater circuit and see if there's a blockage outside of the heater core.
Good luck.
thank you
All three use rubber o-rings to seal and are usually major pain in the butt to remove after baking for 10 years. spraying with pb-blaster and wiggling makes them to give eventually. Don't give up, just wiggle, spray, wiggle. PB Blaster penetrates rubber and makes it soft allowing the sensors to be eventually removed.
Replace o-rings and you are good to go.But make sure to order some U-clips too since the ones on sensors might break from age when you attempt to remove.
