If I disable the TPMS can I use the older sat radio module?
A search brought up the solution to my recurring TPMS problem. Between taking back to the deal, again, to attempt another fix I'd rather disable it.
I also found an XM module, one that only works with the non-TPMS equipped cars for so cheap I bought it on the chance I could figure this out.
It would seem that the TPMS simply used what had been the part of the wiring that previously controlled the tuning on the sat radio. So if I disable the TPMS is there a way to reroute the wiring to the head unit the way it would have been without TPMS?
I know this isn't strictly an allroad question, but you guys are generally smarter than the C5 group, right?
No, the wiring is completely separate. The issue addresses coding on the CAN bus that the TPMS uses.
There was a issues with the programming on the Sat module that the TMPS module also shares causing confusion between the two. They use a different Sat module for TPMS to prevent this.
Wiring is the same for both.
What were the TPMS gremlins?
I am curious as I am looking at adding an OEM retrofit to my 01 AR. If you ever decide to pull your system out of the car let me know I would be interested in the components.
I don't think it's possible to pull the TPMS system out
there are sensors in each wheel, but the system itself is integrated with the onboard diagnostics. The warning that the system was not functioning kept coming on. My dealer replaced one sensor, but that only reduced the not functioning warning to about 50% of the time. Actually, when I make longer trips it tends to work, i.e. no warning display. But my daily commute is about 10 minutes and towards the end of the week, I get the warning display more frequently. Weekends when I make longer trips it doesn't give the warning. Over all it's just not worth the trouble. How hard is it to check your tire pressure regularly? I could easily give up the system in trade for a much cheaper Sat module, but alas, I cannot make that trade. My system is inherently flawed. It's too hard to justify spending full price for Sat radio with a 10 minute commute.
Re: I don't think it's possible to pull the TPMS system out
Interesting, your problem that is. Almost seems if you can keep the temp up in the tire the air may expand enough to keep it above the warning level. I am curious on the system, do the OEM system show you temp and pressure in each wheel? I have never seen the system used.
I know the parts needed, I have the wheel sensors already and might have a lead on the receivers for each wheel then all that is left is the main receiver and control box plus the center consule controler.
Have you checked out navplus.us for an XM module that will work with your setup?
