ipod hardwire options for '04 AR?
Hi Guys,
Posting this on behalf of my Mom who just got an '04 AR. She is in love with it. Anyway, I'm pretty sure what the options are but I was hoping to get some clarification from the AR experts--I'm currently running the Icelink+ in my A4 so I'm familiar with that setup and how it works. I was wondering more about the Audi kit--is that a plug-and-play kit and if so, where can it be purchased? The only thing I found on audiusa.com was something that's for '06 and above.
My iceLink+ kit plugs into the factory CD changer plug in the rear of the car so I'm most comfortable with that setup. Can that be done in the AR as well or does the HU need to be pulled? And if so, how easy is the setup? Does the Icelink+ / OEM kit have a wiring harness that you just plug in?
As far as options, she has Bose, XM (doesn't use it), in-dash cd-changer, but not NAV.
thanks a bunch!
thanks a bunch!
Oem comes with everything and wires, but the XM would have to go
. there are ways to get around (some companies sell adapter wires and harness) but Audi says only 1 accessory. so no SAT. And would not be plug and play since the car has SAT. probably 3 -4 wires you would have to remove from radio harness and then install from Ipod adapter.But easy to do.
You can buy at any dealer if unable to find.
If it is the Symphony II with an in dash cd changer, then you could do a Dice adapter and keep XM
Although I don't have any Sat, I do have the Symphony II with in dash changer. I got a Dice ipod adpater from enfig, so I don't know what the OEM allows for. The enfig adapter they sent with the Dice unit allows for the Sat radio to piggy back on the same plug in. As long as there are seperate buttons for the cd and sat, you can have both. The customer support at enfig were very helpful in getting me the right set up.
I have the Audi iPod adapter in our '01. I plugs into the back of the (more)
headunit but it requires you to unplug the trunk mount cd changer, not sure if the '04 headunit is the same or not. It works using the same controls as the radio, I just wish it would display song info on the headunit. But it is seamless and functions well.
SimonBackman
01-27-2011 10:18 PM
John Stahmann
A4 (B7 Platform) Discussion
42
01-25-2010 09:35 PM
ChriSline
09-22-2008 02:25 PM
Rice Etr
Audi A3 / S3 / RS 3
17
09-23-2006 01:21 PM
