Just completed JHM short shifter install! (added tech article as well)
After much research on short shifters, I decided on the JHM short shifter. It uses a spherical bearing to replace the main pivot. This kit is by far the best engineered unit out there. I have tried many other brands in my A4. This thing totally transforms the sloppy shifting. Do keep in mind I also have the DTS installed as well. Since there was no write-up in the tech section, I wrote up the procedure for everyone.
https://www.audiworld.com/tech/int70.shtml
Eric<ul><li><a href="https://www.audiworld.com/tech/int70.shtml">https://www.audiworld.com/tech/int70.shtml</a</li></ul>
We now have them in stock for all 2000-2005 Allroads
<ul><li><a href="http://www.jhmotorsports.com/shop/catalog/index.php?cPath=21_66_68_169_170&osCsid=bc32a9 db4be051bd889a0909cc45c4de">All 3 versions to cover all the different models since 2000</a></li></ul>
Jonny K
Audi Original "S" Cars
10
04-02-2007 08:13 AM
RMcQ
Audi allroad
12
12-24-2005 11:29 AM
