Key Coding...
Old May 2, 2005 | 10:12 AM
paulroad's Avatar
Tech Guru
Default Key Coding...
OK.. the Directions posted on the forum do work. I had to re code my keys as they stopped working the remote fob functions.
After they recode they both work lock/unlock ets. as they should.
However... one of the Keys while it works is not coded to the Immobilizer so the car won't stay running past 1 second of starting. (this was what i was trying to correct initially)
Any ideas short of ....the dealer...?
Old May 2, 2005 | 12:10 PM
mk4=audi?'s Avatar
Default You can do it, but...
You need the Secret Key Code (SKC)... if you have the set that came with the car, there should be a tag that has the number, if not... dealer... see this link:<ul><li><a href="http://www.ross-tech.com/vag-com/cars/Immo3-ecu-swapping.html">To ross-tech.com -&gt;</a></li></ul>
Old May 2, 2005 | 02:08 PM
paulroad's Avatar
Tech Guru
Default Thanks, but...
I don't need to code an ECU.. I have a key for my car that no longer is coded to the car. Windows and doors work fine, it just wont start it. The other key..its mate is fine in all respects.
Old May 2, 2005 | 02:57 PM
mk4=audi?'s Avatar
Read further...
Old May 2, 2005 | 03:44 PM
mk4=audi?'s Avatar
Default Re: Read further... sorry, wrong link...
Sorry, hasty copy and paste job... this should be better...<ul><li><a href="http://www.ross-tech.com/vag-com/cars/Immo3-key-matching.html">Again to Ross Tech -&gt;</a></li></ul>
ritam2001
A4 (B7 Platform) Discussion
Apr 4, 2007 04:33 PM
Imola Ghost
VAG-COM Discussion
Dec 18, 2006 06:51 AM
MCarson
Audi allroad
Jun 4, 2006 07:40 AM
Airbag79
Aug 28, 2005 08:02 AM
case allroad
14
Feb 24, 2004 10:27 AM
