Phatnoise Cheap!
Phatnoise Cheap!
found this while looking at parts for my other vehicle-should work with an audi too right?<ul><li><a href="http://busdepot.com/details.jsp?partnumber=000057110">click</a></li></ul>
It's not a straight plug-n-play, but you should be able to get it to work...
The radios use the same protocol, but the cable connectors may be different...
I may order one and try to get it to work
Gavin
Gavin
Can't find any ratings for either site at epinions.com or resellerratings.com
Have you dealt with either of these sites with favourable results?
I remember reading an install writeup here and If my memory serves me right it wasn't a straight screw in job. The cd changer bracket did not fit the phatnoise box. Any one already install this? I don't feel like searching as search doesn't find my own posts when I search for my id.
This looks very good as I was considering the icelink/ipod route but this would hold more than enough music for me.
Here ya go (Clair Parts Link)...
These are the two you would need for 2003+ AR (no CD Changer cable in the read)
Mounting Bracket (P/N ZVW269300):
http://www.clairparts.com/accessories4.asp?product_id=2300&PDID=192367
Cable Harness (P/N 4B0051735B):
http://www.clairparts.com/accessories4.asp?product_id=2301&PDID=192410
Regards,
Gavin
Regards,
Gavin
you need Part#000-051-592A if you buy a volkwagen phatnoise. $50 adapter,don't need mounting bracket
<ul><li><a href="https://forums.audiworld.com/a6/msgs/496005.phtml">https://forums.audiworld.com/a6/msgs/496005.phtml</a</li></ul>
You will also likely need the CD changer cable if...
you have a 2002 or newer. I believe since the Symp II has the CD Changer in the dash it doesn't have the CD changer cable pre-wired. Thats $100.
When you add it all up almost same as ipod with icelink, but now you have an ipod you can use
