Problem turning allroad 2005
i just picked up an 02' and it does the same thing...
My friend who works as a mechanic at the stealership is going to check it out this week. I will let you know. Just to clarify our symptoms here. Mine, when turning at slow speeds just off midline axis shudders just a bit. Weird! It does not do this in a straight line which is baffles me more. Let me know what you found as well. Good luck
I did have a similar problem...
Ended up being the CV axles, in the front. Bought axles from a reputable company called Raxles. Problem solved...and that was 20k miles ago.
sam08861
05-31-2008 05:31 AM
