Props to dealer - lesson: always have indy check car prior to warranty ending
Dropped the car off at the dealer this morning. Warranty expires on 9/14. For one hour labor, indy had diagnosed several issues I asked the dealer to look at. Even though indy didn't see any problems with airbags, noticed the car leveling off the last day or so, so asked dealer to look at that too. Dealer called today, covering EVERYTHING without argument. I'm impressed, but also somewhat saddened that a 4 year old car with so few miles has so many problems. Hopefully after all this the car will be tight. Glad to know that if it isn't I'll have Bruce's 5 year/100,000 coverage to back me up.
1. Asked dealer to check battery, assumed it wouldn't be covered and I'd just replace myself, but they are covering it and replacing.
2. Control arms were observed as being cracked, I believe dealer is replacing all
3. One CV boot was observed torn, dealer is replacing
4. Valve cover gasket was observed leaking - dealer is replacing, then will inject dye and check for other leaks - cam seals and lower oil pan potentially
5. They mentioned something about sway bar linkage, which I didn't get since I have H Sports, I'll have to remember to ask about that.
6. On the air bags, they said the control module would be replaced. They said they would then have the car sit for a day, then check the airbags and air pump.
Overall, just impressed with how thorough of a response and pleased I was able to avoid the cost of all those repairs. Meanwhile, got an A4 Avant 3.0 loaner with NAV for a few days, so feeling pretty good about things at the moment.
how do you approach Audi dealer with list of repairs
Do you just tell the dealer you took it to another shop and these are the poblems?
I just feel it might be a little uncomfortable telling them that i took it somewhere else.
Thanks
Thanks
inform the dealer of symptoms that lead them right to problem areas
don't say "the CV boot is torn" but instead say, I noticed alot of grease on the inside of the wheel, can you check that out please.
I see oil burning off the motor in a few places, can you please check that out for me (and show him where on the motor you "see" the oil burning)
giff9
15
05-25-2007 07:06 AM
tk1780
10-01-2006 02:07 PM
going to dealer for my last check up b4 warranty ends. any special things i have to ask my dealer to
0000audi
03-29-2004 10:29 AM
