Question about wheels Im about to order.
I have decided to purchase some 19x8 RS6's with an et of 30 from custom wheels market. They sell Italian replica wheels and for a good price. With my stock wheel having an et of 25, which would be better to go with, 10mm or 15mm spacers?
Use this calculator while keeping in mind 18x8.5 ET20 is the oem upsize.
Also check out www.allroadfaq.com.<ul><li><a href="http://www.1010tires.com/WheelOffsetCalculator.asp">http://www.1010tires.com/WheelOffsetCalculator.asp</a</li></ul>
My 19" X 8.5" x 25et clear just fine.
I only needed a 3mm spacer at the front so my 255 tires would clear the control arm. Had I used 245/40/19 tires I would not have needed any spacers. Perhaps the 19" rim clears better than the 18". The best tire for your 8" rim is a 245. That being the case you only need a 5mm spacer. You can judge what clears by what Tire Rack sells for the ar, they research very thoroughly. I have to believe the thinner the spacer the less there is to attempt to balance. Make sure to Road Force balance.
It matches rim to tire roundness as well as weight balance...see link.
<ul><li><a href="http://www.broadwayautoclinic.com/Balancing.htm">Learn more here...</a></li></ul>
Are the wheels they sell any good? How do they compare to Hartmann?
Trying to make a decision today on RS6 5 spoke reps. I already ordered tires and want to get it all bolted up by the end of this week.
