TDI Problem
Old Feb 23, 2015 | 01:46 AM
amiram's Avatar
Default TDI Problem
I have AR 2002 TDI TIP AKE engine with 220.000 KM on the clock. A month ago I made an accident. Hit the front, radiator-intercooler-condenser-fender- cosmetics, etc. After the accident I drove back home 40KM.Except for a slight cooling fluid leakage from the radiator' car drove fine no problem and no fault codes.
It was an opportunity to replace timing belt, water pump etc, And repair an old cooling fluid leakage under injection pump. After two days of interesting work I put everything back except the fender and front headlights. After draining air from fuel system (2 times) Fuel comes to the injectors.And the engine will not start. The battery ( fully charged)was disconnected for a month, Could this be a problem?
Today I double checked the engine timing and injection pump timing and everything is fine. But the engine will not start. Any suggestions \ comment is welcome.
Sorry for my poor English
Old Feb 23, 2015 | 11:47 PM
dallas0029's Avatar
Hi mate, if you can hook up a diagnostic computer and get any codes from the engine ECU and report back would help and we can go from there. When you do the timing belt you need to recheck the timing with VCDS on the AKE engine.
Old Feb 24, 2015 | 04:26 AM
amiram's Avatar
Default Updated
The problem is resolved. It was a small crack in a clear plastic tube thet feed the fuel injection pump. Constantly sucked air into the fuel system.
Thanks again
Amiram
mh644
37
Dec 18, 2019 10:02 PM
yury
Apr 13, 2017 04:14 AM
AudiRacer94
Sep 2, 2014 09:11 PM
Mr. Timewise
Audi allroad
9
Jan 19, 2014 09:02 AM
the red pill
Nov 24, 2002 05:46 AM
