Uneven front tire wear
2004 Allroad, 210k on the clock. Full maintenance history unknown.
Right front tire often goes soft, I've just been reinflating every few weeks. It leaks around the bead. One of those "I'll get around to it one of these days" type of deals. When tires properly inflated, car is silky smooth at all speeds, runs perfectly straight down the road, no unusual cornering or pulling any way when braking. When tire is low, steering wheel shimmy at low to moderate speeds, pulls right slightly, pulls right harder when braking.
I had the wheels cranked hard today while reinflating the right front tire and checking the other three, to find this. To my untrained eye, it looks pretty fresh. I'm trying to determine if this is a self inflicted wound earned by running an under inflated tire now and then or if I have some type of other mechanical issue such as control arms bad. Both front tires share this same wear pattern. I've had the car for anout a year and a half 10,000 miles, and this is the first I've noticed it, but I don't recall ever checking the insides of the front tires. I've got to think I would have noticed it before.
I think sooner than later the tires need replacement anyway due to weather checking even though other tread is still 50% or better on all four. Tonight I'm planning on getting this thing up on jacks to look at it a little better. Give the wheels the wiggle test at 6/12 and 3/9 o'clock. I know there's a sequence with the ride height controls before lifting the car so I'll have to review the manual for it.
Thoughts greatly appreciated.
I have the same issue with my tires, the inside wear. The previous poster recommended a good tip, about getting the alignment checked.
On AWD cars, I always try to recommend going to a place with lifetime alignment plans, so that you can get it checked annually.
I have inside wear on all four of my tires, and am ready to make a purchase of a new set of continentals. I will also be aligning my vehicle at the same time to make sure I get it all perfect.
It could also be the upper control arm bushings. When they become worn it changes the camber causing inside tire wear like your picture. But it's probably a combination of all the above.
I've had same issue during last summer season. Root cause was following - a wear of bushing of control arm (right and left side lower rearward).
I've renewed all 8 rubber bushing and did alignment - issue fixed.
JMURP
16
04-20-2006 07:58 AM
C-Nutts
Wheels & Tires Discussion
12-10-2003 02:23 PM
kritzer007
07-27-2003 06:18 PM
planux
07-22-2003 04:04 AM
STXPRESS
10-23-2002 06:24 PM
