VagCom suspension code advice needed
Old Oct 2, 2013 | 12:35 PM
ertatta's Avatar
Default VagCom suspension code advice needed
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 B
Component: - 2C1A1 X031
Coding: 25500
Shop #: WSC 09999
VCID: 449980CC54587F38443
5 Faults Found:
01400 - Suspension Level Control
11-10 - Control Limit Not Reached - Intermittent
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
01577 - Turn-Off due to Over-Temp
35-10 - - - Intermittent
08-10 - Control Limit Surpassed - Intermittent
01780 - Sensor for Vehicle Leveling
04-10 - Mechanical Malfunction - Intermittent
Old Oct 2, 2013 | 12:52 PM
GTA_Driver's Avatar
Tech Guru
Do you have a leak in any of your air springs?
Old Oct 2, 2013 | 02:09 PM
ertatta's Avatar
checked out what i thought was a leaky arnott bag this morning. but when i stopped by tire shop, we realized after taking off tire that the air line where it enters the input on arnott was the culprit. noticed that lower portion of arnott lost seal with strut. i did forget to put in "jack mode." so my issue once i got it home and pulled bag down to create seal is that when i put on wheel and dropped car from jack i get an "EPC" light. doesn't seem as though the front arnott's want to fill up even though they do so when car is jacked up. did i screw up a level sensor or throw off it's settings? it would seem that these codes indicate the "suspension control module"
Old Oct 2, 2013 | 05:00 PM
GTA_Driver's Avatar
Tech Guru
I don't think it's the suspension module, because you get reasonable and logical codes. Your compressor constantly pumps air (or at least it pumps a lot), it overheats and shuts off.
You either have a leak in that air bag, or a faulty sensor. The system tries to pump air but cannot reach the desired level.
You do have an error code for the sensor, replacing it may be an idea.
johnd64
Jan 13, 2019 08:46 AM
Eddyg
Jan 23, 2016 07:54 AM
mjeakman
Audi allroad
Feb 7, 2009 05:06 AM
S4ptld
Audi allroad
Nov 2, 2008 06:17 PM
AudiForYou's 2.7T
Audi allroad
Feb 20, 2005 05:40 AM
