1250 mile road trip in a rented Sportback
Some good things...
- I got to put the miles on a 2022 Sportback with the premium plus trim vs. my own vehicle.
- The charging for the entire trip was free. I had 241 credits with Electrify America when I left town. 1250 miles and 428.52 kW worth of charging later, I still have 107 credits. It appears that the network was down on 12/17 which happened to be the day of the first leg of the trip. I see $0.00 for all of those pit stops. Everything after that date has a dollar amount associated with it, but my credits haven't dropped since 12/18 and I have done a lot of charging in between. It looks like the EA network is having some issues right now, at least with those who are using the free credits.
- With one exception, I did not have to wait to plug in, and the one stop where I did have to wait for < 10 minutes was Harris Ranch along I-5. It's Xmas week so I knew it was going to be busy, and I was looking forward to a steak sandwich so I dealt with it.
- I only encountered two non-working chargers, and in both cases there was another available charger that worked.
- I did not drive slow, and the range was not affected as much as I thought. I'm talking 75-80 mph at times. Regeneration while going downhill also made a difference.
Going chronologically so I don't forget anything major...
- Our first stop was in Atascadero where it took 32 minutes to pull 67.6 kWh which got it to 90%. It was here that I noticed that charging stations are not always in a good location where you can get some food, or find other ways to kill 30-60+ minutes. Our options at this particular location were a gas station and a Subway. (Strike one for public charging stations).
- Our next stop was Westlake Village which is northwest of LA. It took 29 minutes to pull 53.4 kWh which got it to 80%. The station was initially full when we pulled up, but a guy with an etron was trying to plug in, couldn't, and then pulled out of the spot. I pulled into the spot that he vacated and plugged right in while he waited to try another one. What happened is that it was the first time that he had used a public charger, and didn't know that he needed to pull down the DC cover. I showed him how to connect it, but he ended up having to wait. Sorry dude.
- Charging while we were in SoCal was uneventful for the most part. I almost got paint all over the car as I was pulling out of a charging station in Vista. Some db dropped a gallon of paint out of the back of his truck. Fortunately, I saw it coming and moved to the right. I ended up getting a little paint on the front left tire which got a little in the wheel well and a couple of spots on the inside of the rim. I wiped off the drops that got on the rim. No big deal. A couple of other cars didn't fare as well. They got blueish gray paint all over one side of their car. Again, not all of the charging stations were in places where there was much to do. The night before we left I topped off and charged from 73% to 100%. It took 26 minutes to pull 24.8 kw. I also noticed by then that chargers that do reach the 147-150kW range start to throttle back once the SOC gets into the 71-73% range. By the time you hit 80% it's more like 100kW and it keeps dropping from there. This means that you are looking at nearly 60 minutes of down time if you are on a road trip and need to charge to 100%. (Strike two)
- Now, I should point out here that Audi's are among the fastest charging EV's out there right now. I encountered a number of other EV's at stations that take for-ever to charge. When I pulled into Harris Ranch I saw mostly Chevy Volt's and some other dumb looking EV's that apparently also take for-ever. Of course, they are all charging to 100% as well so they take even longer. While I ate my steak sandwich and moved my etron out of it's spot when it was done, I saw three etrons including mine charge and leave while a Chevy Volt sat there the entire time, and it was still there when we left. I really want to call strike three at this point, but I'll wait.
- As I got closer to home, the charging speeds dropped. I had been doing okay up until that point. Some would take a few minutes to ramp up, but most would end up pulling at least 120kW. Once I got close to home, and after I got back home it was more like 80-90kW. My biggest takeaway from using public charging stations is that they are unreliable (Strike three).
- Oh, last story and sorry if I'm being long winded. While I was charging near my house the night before I took the car back to the dealership, some cat in a BMW iX pulled up. There was an empty station, but the cable wasn't long enough to reach the port that is stupidly located at the rear right side of the vehicle. He had to wait for a slow charging VW to move before he could plug in. Holy hell, that sucks. I noticed the charging port location when I looked at an iX. The Mercedes EQS SUV has the same issue. The single port is where the gas cap used to be and half of the stations are unusable to them unless they drive up a curb and park half of the vehicle in the dirt. Ford and Audi got it right when it comes to the charging port location. BMW and Mercedes got it wrong.
After this trip, these are the reasons why my next road trip, and probably several more after that, will not involve an EV....
- It adds 1.5-2 hours to what would otherwise be an 8 hour drive. This is not good, especially with a couple of kids in the car. The biggest issue that came up is too much time being wasted at charging stations due to unreliable charging infrastructure, and the etron's mediocre range.
- It is NOT cheaper than a gas burner. Had I paid for the charging out of pocket, 428.52kW would have come to a little over $184. In our Honda Accord Hybrid, the same trip would cost about $120. The EV will beat some gas guzzlers, but most gas burners will get you there much faster and for less money.
- The possibility of having to wait just to charge the car. I got lucky and only had to wait for a few minutes once, but if you get unlucky and the stations are full that can really make for a long day on the road. If you are the only one suffering that's one thing, but if you have kids in the car or have to be somewhere at a certain time, the unpredictability is a deal breaker.
Takeaways....
- If you typically drive < 100 miles per day AND can charge the car overnight while you sleep, EV's are for you.
- If you have a really long commute, have to rely on public charging stations, and/or plan to take long road trips, I would wait a couple of years before buying an EV. Battery range, charging speed, and infrastructure all need to improve.
- After driving the mid-trim etron Sportback, I am really glad that I got the high trim. It was worth it.
- Driving over the Grapevine did not cause the battery range to crater. It wasn't nearly as bad as I thought it would be.
in regards to your cost, you have to consider that a good majority of your charging will be done at home. Your road trip was also done during the winter, when efficiency is impacted the most. In my experience, during the summertime in ideal conditions, I’m able to hit 2.7-2.8 mi/kWH. My cost driving from the bay to LA is a lot cheaper than if I were to take my Q5 which does about 28 mpg.
Cost per kWh varies widely by location and charging company. Many areas still charge by the minute which greatly benefits the e-tron.
Your time estimate is too long, unless you are getting reduced power or the battery is cold, or something like that. Hey, Audi, put in a temperature gauge for this reason, please.
More like 40 minutes, 0% to 100%, which should never be the plan. Note that below 6% is also reported to be slower than 100kW, I've never tried that low. The longest actual charge time I've had with the etron (USA, so 55) was 34 minutes, which was ~20% to 100%.
I've seen usually less than 1 hour on an 8 hour drive. 8 hours at about 70 MPH is a little over 500 miles, which is 3 stops of about 20 minutes each. I'm very unlikely to stop only three times, as the wife's bladder usually isn't good for 2 hours. The EV isn't usually slower than a gas car would be for me but your situation is different.
This is the real win use case for an EV, daily driving.
If you can't charge at home or work, I'd wait on an EV until there was a good, reliable and convenient daily charge.
Long trips, depends on where to and how tight of schedule you have. A trip to Sleeping Buffalo MT, for example, would be a huge pain. Without crossing the border with Canada, the closest public charging of any sort is 201 miles away. Or an RV park, often an interesting experience. Oh, and that is an L2. Want 150kW? That's 380 miles away or more, unless you go into Canada.
On the other hand, some longer trips are fairly easy, with alternatives so should be fairly predictable. Depends on how much you do this, as well. Once a year is probably OK, to many destinations. Once a week would be a pain.
Also, let me clarify that my experience since buying my etron at the end of July has been really good. I have a short commute to work, and I am fortunate to have a garage with a charger installed. Other than this road trip, I have used a public charging station once since I bought the car. I will take the etron on day trips to Pt Reyes, or visits with the in-laws that will only require a short stop of 5-10 minutes to charge on the way back. For now, I will stick with the gas burner on long road trips, and revisit this in a couple of years. I am fine with my 2022 etron for the time being, and plan to keep it until the new platform becomes available. There is a chance that I might swap it for a 2024 if the resale value of my 2022 is good enough, but I don't think it's likely.
I expected Harris Ranch to be busy, especially since it was Xmas week. I would not expect to have trouble finding an available charging station there most of the time, but it's the travel season and a lot of people are out on the road so I figured that I would be waiting at some point. There are a few key locations on I-5 that could really use more charging stations. The Enos Shell just north of the Grapevine is #1. The EA app shows that one being full most of the time during daylight hours. It's a popular place to stop for southbound traffic because even the lower range EV's can at least get to Orange County from there.
Is the charging free? Most of the time, no. Sometimes you get lucky and the network is down.
Is it cheaper than gas? If you are using public chargers, not really. Charging at home is where you save the money.
I didn't record all the peak rates, but the others were all near 150kW. And there were a few time I switched chargers because of a low charge rate.
The last one was in Frisco, CO. Four chargers, one I couldn't use without driving onto the landscaping and two in use. Mostly a stop for the usual reason, but wanted a little extra for Vail Pass while we were there. Was sleeting in late May in Frisco, 2766 meters or 9000 feet altitude. Snow on Vail pass.
Could have been a schedule breaker. But didn't really need the stop.
TL;DR: if you get the dreaded 35kW charge rate, just unplug and move to another dispenser (or try the other cable on the dispenser). Odds are pretty good you'll get full speed on another one.
