2024 Q8 e-tron brake pulsation
Sounds like your ABS is engaging, which may be normal in those circumstances. Are you driving with auto-regen enabled? If so, you may expect it to kick in but it doesn't and then you find yourself braking late, thereby engaging the ABS.
There's an algorithm for enabling/disabling regen, but it's not entirely transparent under what circumstances regen is disabled (legit and necessary on slippery surfaces, for example). It can be disabled based on ambient temperature, perhaps also based on weather conditions (gathered from the wiper sensor and possibly other sources) and also possibly based on the state of charge (i.e. if close to 100% - Teslas did that, I'm not sure if Audi does that too, given the allocated top buffer). It's also possible that, in their German wisdom, they are not just disabling automatic regen but regen altogether. While this does eliminate automatic regen, it also entirely eliminates the electromagnetic component of braking, completely changing the pedal feel and the brake engagement characteristics.
I too have experienced what you're describing, a handful of times. The EM braking was absent, had to brake harder for what would otherwise have been a smooth stop, from normal speed. It always happened in the same spot (the first intersection out of the neighborhood) always on a colder day, with a cold car, freshly charged to 80%. Every time the behavior disappeared shortly thereafter (after one or at most two stops). I suspect it's just a crummy algorithm and lack of visual indication that regen is disabled/diminished. It probably uses the first significant deceleration event to assess conditions and then settles on a setting. It's also quite likely that this happens in a narrow temperature range, just above 0C/32F.
Could just be flash rust from sitting overnight in humidity causing the brakes to pulse the first application as it cleans the rotors.
The Etrons are programmed for a "rotor wipe" function several times each day, usually when first starting out. What that is - is use of only friction brakes in order to remove deposits. The parking brakes use the disc pads, which leaves deposits on the rotor - hence the pulsing. Simply watching the power meter will reveal when this is happening when you step on the brake.
Either way, crummy implementation as Audis have had the disk wipe feature for a long time, but none of the old ones exhibit this less-than-ideal behavior.
What we're all describing here is either a new and poor implementation of that or something different. Either way, it doesn't seem to be too frequent or too dramatic.
