Jerky Brakes Issue, Rocks back and forth ??????
I love m E-tron SUV 2021 but when braking the vech rocks back an forth, was told that is normal, dont remember when I test drove that it was so jky, it rocks back and forth slightly before a full stop, I know about teh recall but that shouldn't effect it, mech told me Audi are different frm Tesla which doesn't do this, so has anyone had this issue? That is usually new car service dept famous line its normal. so does anyone etron
Same thing for me…..the harder I break the more it rocks at lockup. You really have to feather it in to have a smoother stop.
I get the same thing, but only if I brake with constant (hard) pedal pressure all the way to a stop, which wouldn't be a smooth way to stop in any vehicle, much less a 5,600 lb. e-tron.
Ease off the brake pedal just as you're coming to a complete stop, and just as you come to a stop, the hold assist will grab and you get a bit of a bump, but not bad. If that bothers you, you can disable hold assist so that you can feather the braking all the way to a complete stop.
kataja (08-08-2021)
E-Tron uses brake by wire, there is no physical link between the brakes and the pedal. When you press the brake pedal under normal circumstances the regen motor slows the car down initially and the mechanical brake will stop the car during the last few feet. Ease off the brake pedal as you are coming to stop.
kataja (08-08-2021)
This is an issue with how they blend their regen braking and mechanical braking.
I think if you are full on the brakes and do not ease up as you slow down, the mechanical brakes will bite a bit too hard and since they are so much stronger than the regen, it gives you this sudden jerking stop.
I've noticed that when slowing down entirely by regen to a near stop, I can feel the sudden mild jerk(and hear a creak) as the mechanical brakes bite as it stops.
Club AutoUnion
I have never experienced this issue in my 2019. In my experience braking to a stop hasn't been any different that any other car I've owned.
