Is the low efficiency of Q8 e-tron anything to be bothered about?
#11
#12
etron efficiency is lower because it's full time awd, many of the newer EVs offer 2wd variants now. also, etron regen is very weak which lowers overall efficiency, which i actually prefer since it "feels" like a more normal driving experience. i have a teen learning to drive now and i don't want him to not be able to drive a gas car because he's not used to braking on his own. compare that to EV's like the mustang mach-e that are so aggressive with regen it makes some people carsick.
also, many of us have 21's on the etron vs 19's which is going to lower efficiency by quite a bit. but i'm ok with that trade off too, you have to pay to play
#14
The following 2 users liked this post by JNealCox:
Bill33525 (12-13-2023),
thebishman (12-13-2023)
#15
SEE TECH NOTES
50198 CUST REQ CHECKED ALL BATTERY CELLS, ALL OK. BATTERY LEVEL OK.
NO WARNINGS ON DASH OR FAULTS STORED. EXPLAINED CUSTOMER THAT RANGE MAY BE REDUCE DEU TO BATTERY WEAR, USE OF ELECTRIC CONSUMER | SEAT HEATERS, A/C, LIGHTS, RADIO, ETC.) AND ALSO DURING WEATHER CHANGE AS IT GETS COLD THE INTERNAL BATTERY HEATER MAY ALSO CONTRIBUTE TO LOW RANGE. ALL OF THESB ARE PART OF THE NORMAL OPERATION OF THE ELECTRIC VEHICLE. NO REPAIRS NEEDED. OPERATING A DESIGNED
Another words, standard answer for unknown issues. Still no answer my why now at the 80% charge it shows only 120 miles vs year ago same weather and driving conditions was 140 and so on … I’ll report back next winter when I see it at 100 miles 😜
#16
If your nominal range used to be 220 miles at 100% SoC, and now you’re seeing 160 miles, that is a 27% reduction in range. That is not completely out of the ordinary IF the 220 miles at 100% SoC was noted in the Summer months, and the 160 miles is noted to be during markedly colder weather, and if say your most recent driving has been at a high speed and in bad weather, such as rain and wind.
It’s more, way more range drop than I ever saw but I was always parked in the garage; (non-heated however) and pre-conditioned the battery prior to leaving home in the morning.
What is your current, short term efficiency expressed in miles/kWhr?
#17
NO, etron regen is NOT very weak! You don't have One Pedal driving, but when braking, regen brings you very close to a full stop. Remember the brake pedal is using mostly regen (perss down regen) to slow the car. The paddle shifters work only to transfer a percentage of the regen to the accelerator pedal (lift up regen).
#18
#19
sorry i meant to say very weak compared to some of the other EVs out there. i use the paddle shifters all the time but it's nothing compared to what tesla regen feels like, and if you've ever tried a mach-e that thing literally lurches you forward the instant you let off the accelerator! i do not dislike the audi implementation, but paddle shifters or not, it is not the same drastic regen offered by some other brands (which IMHO is a good thing)
thebishman (12-14-2023)
#20
Also, regen is NOT efficient. Nothing can be more efficient than preserving momentum and shedding momentum is what the brake pedal was invented for.
